Redirection problem?
Tony_W
Redirection of email seems to be working but I am also getting a duplicate which is not redirected.
Is anyone else experiencing this, or is it just me?
This was not happening yesterday.
Tony
3 REPLIES 3
7up
Fixes: 17
Re: Redirection problem?
Via the relay server? I've not seen anything issues and I've probably sent around 500 emails through it in the last 72 hours.
jelv
Fixes: 10
Have you looked in the message source to see if both copies have the same Envelope-to: etc?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Tony_W
Ah I think I have found the problem.
The problem is at my end. I did a windows update this morning and have lost an outlook folder. That folder is used to retrieve a copy of my gmail mail which is where I redirect some of my email (so that it gets additional spam filtering).
Outlook could not put the emails into the non-existent folder so they showed up in my main area as duplicates.
Looks like it was my fault for not noticing the change.
Sorry...
Tony
