Really dumb question....
FIXED- Subscribe to RSS Feed
- Really dumb question....
31-12-2019 11:39 AM
Hello - I've been a plus.net customer for a few years, but never wanted to create a plus.net email account - until now. I've watched the Video but I can't seem to login. It asks for my username and password.... Are these my plus.net account username & password? When i use these it just comes back with 'login failed'. What am i doing wrong?
Fixed! Go to the fix.
Re: Really dumb question....
31-12-2019 12:24 PM - edited 31-12-2019 12:25 PM
Hi @Wooster
A warm welcome to the forums … there is no such thing as a dumb question when you do not already know the answer!!
Just to check...
- Do you have an active account which you are paying for (that is not a legacy free email account)?
- Are you logging into the user / account portal (not webmail)?
- Are you with Plusnet or one of the legacy brands?
The link you gave refers to using the WEBMAIL service - on that page there is another link (https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/) which advises on how to set up email addresses - which you need to do before you try to use them!
31-12-2019 2:43 PM
Hello Townman - An active account? I get my broadband & phone from Plusnet - to I'm assuming this means I have an active account? I'm log on through this page: https://www.plus.net/member-centre/login So - yes, I'm with plusnet. I'm only interested in using a web-mail address - I don't want to use MS Outlook etc. (I'm happy with an @plusnet address.)
31-12-2019 4:40 PM
My apologies - the link I gave you from the how to USE webmail page does not expressly advise on how to set up email addresses (as I expected it to). You need to follow the further link on that page https://www.plus.net/manage_my_mail/ to ESTABLISH the mail box.
Indeed the rest of that page does describe CONNECTING to an existing mailbox using an email client.
Webmail is just another email client … you still need to create the email addresses using the Manage My Mail option in the user portal. That page I pointed you to presupposes that a default address exists … which is the way the email system used to work. I will ask for the page to be reviewed.
31-12-2019 5:04 PM
Thanks for this. Completed the necessary fields, and now just waiting for the conformation from the 'postmaster'. Grateful thanks
31-12-2019 5:06 PM
That email address should already be ready for use - just try logging into it using webmail.
02-01-2020 11:21 AM
