Problems with email on iPad
- Re: Problems with email on iPad
14-01-2016 6:41 PM
Why can I not access emails with my Plusnet address on the iPad? Why does the iPad not accept my details?
Do other people have this problem?
Have tried to get them through gmail but that does not seem to want them either on iPad or iMac.
Asked in support and just got told to use webmail! But that is not acceptable.
15-01-2016 11:23 AM
If the iPad will not connect, then it usually means that you've mistyped something. I've got several PlusNet email accounts configured on several devices without issue.
Are you configuring it for imap or pop3 operation?
When it goes through the verification process, it will initially fail asking if you want to try a non-SSL connection, to which you should say yes.
15-01-2016 12:18 PM
15-01-2016 12:27 PM
16-01-2016 8:01 PM
16-01-2016 9:18 PM
David
16-01-2016 9:57 PM
19-01-2016 2:03 PM
19-01-2016 6:05 PM
David
20-01-2016 10:43 PM
Still cannot understand why Plusnet email address cannot be verified but will persevere.
25-01-2016 12:49 PM
25-01-2016 3:07 PM
27-01-2016 7:52 PM
