Problems with Webmail
- Re: Webmail speed
Re: Webmail speed
10-07-2018 12:46 PM
Re: Webmail speed
14-07-2018 12:08 PM
It was Henry the 2nd of England referring to Thomas Becket that once said "Will no rid me of this troublesome priest"
This phrase came to me this morning whilst, yet again, I wait for the error ridden webmail to deliver my emails.
Re: Webmail speed
14-07-2018 12:11 PM
We've been told before to regularly delete emails off the server. I deleted a number of mails earlier and now they are back again!
Re: Webmail speed
14-07-2018 12:34 PM - edited 14-07-2018 12:37 PM
As you may know if you read this topic frequently I now use Gmail instead.
However I thought I'd log onto PlusNet email to see how it was now - so I've just done so, counted up to 153 (i.e. seconds) and got a timed out message.
So, basically, Webmail is unusable at 12.30pm on a Saturday afternoon...
EDIT - I can access other folders but the Inbox refuses to load. Just deleted 99 emails in my Deleted folder to see
if I can replicate the above.
Re: Webmail speed
14-07-2018 12:38 PM
Yes I gave up this morning. Timed out every time. I've just managed to get emails up now. I've not tried deleting any yet though.
Re: Webmail speed
14-07-2018 12:56 PM
I've set up Thunderbird on my PC & get emails via IMAP which mostly works, provided I do this frequently.
Most email goes to Gmail + I take backups of Gmail onto my PC.
I also take backups of the backups on my PC to external devices.
Re: Webmail speed
14-07-2018 1:02 PM
I use Webmail to A) allow me to view incoming mails when I'm not at home and B) to delete the spam and mails I do not want before I download everything I wish to keep on my PC.
Therefore I do not have hundreds or thousands of mails on PN servers so cannot be accused of clogging up their system yet still the performance is frequently slow and unresponsive.
Re: Webmail speed
11-09-2018 2:14 PM
Don't know how this issue is progressing but Webmail is running a lot livelier these days, for me at least.
Re: Webmail speed
11-09-2018 3:23 PM
Well I've just tried and I have to agree - at least with the minimal contents I've got there now.
Still takes ten seconds to load my Inbox.
However I gave up on PlusNet webmail months ago now. Switched to Gmail where I already had my email archive stored.
It's SO much better than PlusNet Email in almost everything except Compose - which is infuriating to use since it doesn't display all the headers. Searching is an absolute DREAM to use and so quick!
Re: Webmail speed
11-09-2018 3:52 PM
14 seconds from clicking 'Login' to a fully populated Inbox of 1271 messages.
By recent standards that is flying... and very workable.
Re: Webmail speed
11-09-2018 4:25 PM
But Plusnet have gained a very bad reputation for reliable email.
Re: Webmail speed
11-09-2018 4:28 PM
Agreed. They have some pretty long bridges to rebuild.
Re: Webmail speed
29-09-2018 1:01 PM
As somebody who rarely uses Webmail and prefers to download my messages via my email client I see no changes in the last two years except maybe that the service has gotten worse!! Typically my emails take an average of 3-5 minutes to download most days which is pretty poor if you ask me.
I have only just spotted this, as I rarely look at the thread now.
I am not clear from the above comment whether you are/were suffering slow email downloads on your email client or on PlusNet Webmail, but if the former, you may be interested in the following:
I was experiencing extremely slow email downloads to Outlook 2016 (Office 365) after it underwent an 'upgrade', but it turned out (as you can see) to be related to DNS server address resolution in the PlusNet router, and I got round it by substituting (at first) Google's DNS server addresses in my network definitions (instead of leaving the router to do the job) and later the PlusNet ones (better than having Google spy on me) - see message https://community.plus.net/t5/Broadband/POP3-emails-throttled-on-PlusNet-broadband-affects-both-PN-a.... If you are experiencing slow downloads of emails to your email client, it would be worth reading this thread right through.
If I remove this setting and revert to letting the PlusNet router do the business, then the problem returns, so I am continuing to use the explicit DNS addressing.
Re: Webmail speed
29-09-2018 1:50 PM
Are you referring to the settings as found in these windows? If so did you change the TCP/IPv4 ?
I heard the other day that it's better to use 1.1.1.1 as the preferred DNS and 1.0.0.1 as the alternate
Re: Webmail speed
29-09-2018 1:51 PM
Actually, a DNS lookup only leaks your IP address and the name of the web-site plus date & time. This is not very useful to Google unless it is used in conjunction with the embedded Google code found on most websites.
