Problems with SMTP server (2012-02-26) - SOLVED
- Problems with SMTP server (2012-02-26) - SOLVED
26-02-2012 5:21 PM
Is anybody else having problems sending using the PlusNet SMTP server, or is it just me?
Message 1 of 4
(1,289 Views)
3 REPLIES 3
Re: Problems with SMTP server (2012-02-26)
26-02-2012 5:29 PM
You don't use SMTP to send you use say 3G to send with.
Message 2 of 4
(366 Views)
26-02-2012 5:36 PM
Thanks, but I think you're wrong.
http://en.wikipedia.org/wiki/Simple_Mail_Transfer_Protocol
http://en.wikipedia.org/wiki/3G
My connection to the web (PlusNet ADSL) is fine, it's just that PlusNet's SMTP server isn't responding.
I haven't changed any settings in Outlook.
Message 3 of 4
(366 Views)
26-02-2012 5:39 PM
Closing down Outlook and starting it again has solved the problem. I really should have tried that before posting. Sorry.
Message 4 of 4
(366 Views)
