Problems sending emails
- Re: Problems sending emails
24-09-2011 2:27 PM
Is anybody else having problems sending emails using PlusNet's servers and a PlusNet ADSL connection?
Message 1 of 5
(1,045 Views)
4 REPLIES 4
24-09-2011 2:42 PM
Reported error (0x8004210B) : 'The operation timed out waiting for a response from the sending (SMTP) server. If you continue to receive this message, contact your server administrator or Internet Service Provider (ISP)'
Message 2 of 5
(465 Views)
24-09-2011 2:53 PM
no problem - just tried sending a test email.
However an hour or so ago websites wouldn't resolve (I use a mixture of Plusnet and Google servers) but then cleared itself so I wonder if something isn't quite right
Message 3 of 5
(465 Views)
24-09-2011 6:58 PM
Thanks for checking. I'll try again later. If nobody else is having problems, I guess it's a temporary problem.
Thanks again.
Rob
Thanks again.
Rob
Message 4 of 5
(465 Views)
25-09-2011 8:04 AM
Works OK now. Thanks.
Message 5 of 5
(465 Views)
