Problem with SMTP/POP servers?
Legend
Fixes: 255
Following an SMTP 'server timed out' problem earlier this morning - which appears to have nearly been rectified - I have noticed the POP servers are also very slow. MailWasher is taking a long while to establish connection for each of my accounts where it is usually instantaneous, and Thunderbird is similarly affected.
Anyone else noticing this?
https://community.plus.net/t5/Email/Email-not-working/m-p/1648883#M28266 includes my original observation.
32 REPLIES 32
RobPN
Fixes: 13
Re: Problem with SMTP/POP servers?
I hadn't received an expected daily email (sent around 6:00) from my NAS this morning at about 8:30 so tried sending a few test emails to various accounts with various results, some failing to send but others eventually going, so I couldn't decide whether it was just outgoing or incoming as well which was at fault.
The ones which didn't fail to send didn't arrive immediately and it wasn't until I noticed a flurry of emails received over a period of a few minutes that I thought the fault/s had been resolved so didn't bother reporting.
However, on sending a test email a few minutes ago it seemed a bit sluggish at sending, but arrived promptly.
Legend
Fixes: 255
Thanks for confirming, @RobPN  - so there IS a problem, albeit maybe intermittent.
My receiving is still very sluggish, but as said in that linked post, sending seems to work - for the moment, and not as quickly as it should.
Yes I do @jab1, when I select my Plusnet account on Thunderbird I get a busy 'wheel' that hangs around for varying degrees of time and as noted this is not the normal behaviour.
Legend
Fixes: 255
Thanks, @Anonymous . Hopefully, a clued up PN staffer will maybe start some investigation.
Kelly
Fixes: 9
We're looking at this.
Kelly Dorset
Ex-Broadband Service Manager
JonoH
Fixes: 157
We attempted some work on the mail platform last night (hands up here I forgot to add the Service Status). We're currently rolling back that upgrade as it's caused some unforeseen issues. Apologies for the issues experienced.
 Jono H
 Plusnet Community Manager
+10 to @JonoH for being honest here, if only it were always* this way.
* I don't mean you @JonoH but in general.
Legend
Fixes: 255
@JonoH Marked your reply as a 'fix'. All seems to be okay now.
@jab1, @JonoH Are you sure this is fixed? If the delays I'm having are anything to go by then the answer is No.
Kelly
Fixes: 9
Can you send over the headers on the delayed mail so we can have a look?
Kelly Dorset
Legend
Fixes: 255
Seems to be for me, @Anonymous , although MailWasher is a tiny bit slow to connect to the server. No delays between time sent/received and most importantly (for me) no lag on Thunderbird.
@Kelly, I assume that’s directed at me? If so see below.
@jab1, It does appear to be intermittent, some times the connection is instant while at others there is a noticeable lag with the Thunderbird status bar telling me its sending login details for example.
And just to clarify, I don't get / send much email on this account so I don't really know if it's being delayed. The point I'm making is down to the delays I am getting while connecting to the server.
Legend
Fixes: 255
The TB delays I was having yesterday have gone, like you, yesterday I was having those noticeable delays on TB - but not today. MailWasher, though, does still seem to be struggling for the initial connection.
I have just selected my Plusnet account in Thunderbird and it took 10 seconds to connect 5 of which were sending the login details. So how odd is that!
