Problem downloading mail on IMAP
- Problem downloading mail on IMAP
15-09-2011 1:15 PM
I'm having issues syncing mail using IMAP. I get an error of "TCP connection unexpectadly terminated by the server."
It then seems to download my mail, but each e-mail in Outlook has the same subject, but the contents are fine. If I use the webmail, the e-mails are fine.
I've checked the service status, and the latest problem that was from Monday is apparently fixed. Is anyone else having issues with e-mail at the moment?
Cheers
Griff
Cheers
Griff
Message 1 of 5
(1,279 Views)
4 REPLIES 4
Re: Problem downloading mail on IMAP
16-09-2011 12:42 PM
.. I get that.. my firewall (Smoothwall Express 3) keeps blocking port 14300. But as I don't know all the pnet mail servers' ip addresses I can't exclude them
Message 2 of 5
(609 Views)
17-09-2011 3:26 PM
It seems ok on my iphone, just not in Outlook. I've got access through the firewall ok, and it's been working fine for ages.
It seemed to happen when I recieved an e-mail with an attachment. After that all my e-mails started coming down with the same subject and header info, even though the contents were fine.
I've created a new mailbox, and that seems to be doing the same too. I might try deleting the mailbox/settings out of outlook and recreating them.
Message 3 of 5
(609 Views)
18-09-2011 10:39 AM
I have noticed of late my Magic Mail monitor programme <http://sourceforge.net/projects/mmm3/>, which monitors multiple e mail accounts, cannot connect with the Plus Net e mail server. <mail.plus.net>. I wonder if there has been some configuration change.
http://sourceforge.net/dbimage.php?id=62399
Message 4 of 5
(609 Views)
20-09-2011 12:18 PM
Whilst there have been a few config changes of late, there's nothing that I would attribute to either of the problems you're seeing?
@Griff, did you get to the bottom of your problem? I'd be interested to know whether or not you experience the same problem in another mail client like Thunderbird? @Gel, there was bit of blip last Tuesday afternoon (13th) but aside from that I can't think why your client wouldn't be able to connect to the server.
Message 5 of 5
(609 Views)
