Port 25 on mobile has stopped working ?
- Port 25 on mobile has stopped working ?
07-05-2012 8:35 PM
I can recieve emails no problem but for the last 3 weeks or so I can't send emails Just stays in outbox....Will send over ethernet connection but not the mobile connection
Is it port 25 being blocked by 3 broadband ?
any help gratefully recieved
Pop email works but smtp on relay.plus.net won't work
Leighton
Leighton
Message 1 of 6
(1,793 Views)
5 REPLIES 5
Re: Port 25 on mobile has stopped working ?
07-05-2012 10:57 PM
Yes 3-mobile block access to external mail relays on port 25 and at present only port 25 works with relay.plus.net.
You don't need to change your "from" address but do need to use 3-mobile's own server at smtp-mbb.three.co.uk, port 25, no authentication when on a mobile connection.
David
Message 2 of 6
(520 Views)
12-05-2012 12:23 PM
plusnet really need to get there act together and enbalbel port 587 ASAP, it's not just 3 that are blocking port 25 now many many other providers are.
james.
james.
Message 3 of 6
(520 Views)
12-05-2012 1:32 PM
It would be nice if they'd support RFC 3207 while they're at it, but I wouldn't hold your breath...
Message 4 of 6
(520 Views)
12-05-2012 1:37 PM
The problem is that control over port 25 was introduced to limit spamming/relaying.
If "everyone" has an alternative (and the same alternative) then it's back to square one, isn't it?
I know it's a PITA (to an extent) but why NOT use the server provided by your connectivity service?
It's only a nuisance if you keep switching networks, e.g. a laptop moving wifi lications a lot.
A phone will usually be on the same network all the time, unless roaming abroad.
Message 5 of 6
(520 Views)
12-05-2012 7:38 PM
The thing is you use gmail , .me.com or any of the other providers that offer 587 and ssl you have no problme sending email for nearly anywhere, BT Internet customers are better serverd by the connection to yahoo for email that us Plusneters are.
James
James
Message 6 of 6
(520 Views)
