Plusnet webmail problems when using ipad
- Re: Plusnet webmail problems when using ipad
17-12-2014 11:05 AM
I am totally new to the forums, please bear with me!
I have a problem when checking my mails using webmail on my ipad. I login no problem but when I try to scroll through the mails by flicking my finger this does not happen, I can only see the first nine mails, if I uncheck the preview pane obviously I can see more mails but again I cannot scroll. Everything works fine on my pc and mobile (android).
I have contacted Apple and they say the problem lies with PlusNet and vice versa, its rather annoying.
Any help would be most appreciated.
Thanks.
17-12-2014 11:36 AM
I would say to check that the reading pane on your Ipad is not selected to reading mode (open with a book in the address bar) to see if this improves the issue.
Alternatively try using 3 fingers together to scroll down assuming it does not let you scroll down on any other page/pane but if this does not work, i have no other suggestions, other than to not use web mail and maybe attempt a set up on the mail application on the Ipad.
this link may help if you decide to do that.
http://www.plus.net/support/email/setup/ios-setup.shtml
17-12-2014 11:37 AM
17-12-2014 11:46 AM
Webmail uses frames ipad doesn't like frames.
17-12-2014 12:03 PM
Welcome to the forums.
I have just looked at this and can assure you that this is an Apple Safari issue for which you are unlikely to get a remedy. There are functional limitations of touch screen interfaces.
1. The iPad does not show a scroll bar for the mail items - touching the area in an attempt to scroll the list selects an item to be displayed in preview.
2. The iPad does not show the content in preview correctly - instead of keeping it within the screen and showing a scroll bar, the preview content overflows off the screen. Attempting to scroll email list then shrinks the screen.
Best option is to turn preview off!
17-12-2014 12:06 PM
Quote from: Midnight Webmail uses frames ipad doesn't like frames.
In what way?
Websites I have developed using iframes appear to work fine on the iPad.
17-12-2014 12:34 PM
http://javascript.info/tutorial/frames-and-iframes
17-12-2014 9:30 PM
17-12-2014 11:02 PM
18-12-2014 8:32 AM
@Shipley22, I do not think this is an issue with safari, so much as it is an issue with the touch screen UI. Touch screens defeat a lot of ruch functionality on web pages, especially in respect of hover and scroll functionality.
18-12-2014 9:19 AM
To be is to do - Kant
do be do be do - Sinatra
18-12-2014 9:47 AM
Quote from: PeterLoftus I've tried it works on Hudl but does no work on iPad with Google Chrome or Safari
In this case i would give it up as a limitation to the Ipad and hope that it gets sorted in some update to the Ipads system possibly?
21-12-2014 10:23 PM
21-12-2014 11:03 PM
22-12-2014 9:41 PM
