Plusnet E mail on Kindle Fire
- Plusnet E mail on Kindle Fire
17-06-2013 9:42 PM
Outlook express was woking O.K and now I am unable to receive though .I can send, I have set my password then ----- imap.plus.net -- Security none------ Port 143
It says E mail adress or password incorrect Any advice apreciated My O.E express on my main computer is set POP 3 and leave message on server Why should thiis sudenly fail Thank You
Message 1 of 3
(1,537 Views)
2 REPLIES 2
Re: Plusnet E mail on Kindle Fire
18-06-2013 3:51 PM
A common mistake is to get the the username set incorrectly. Make sure you've not included any broadband details after the username such as @plusdsl.net for example
It would be worth having a read through the info on this help page too: http://www.plus.net/support/email/troubleshooting.shtml
Adam
Adam
Message 2 of 3
(389 Views)
18-06-2013 4:50 PM
Thank you that is exactly what was wrong , my user name, I put the wrong one in when I changed something Thanks again
Message 3 of 3
(389 Views)
