PlusNet webmail and IE10
- Re: PlusNet webmail and IE10
16-08-2013 2:17 PM
I'm not sure if PlusNet staff visit the e-mail section of the forum, but;
It seems that some of PlusNet's webmail doesn't like IE10 too much.
If I open an incoming email that has multiple recipients and click on the reply to all button, it opens a new e-mail, and adds the sender in the To field. But the CC/BC fields ends up being about 10 pixels wide and you can't see or edit the list of recipients in it.
If I hit F12 in IE to bring up the developer toold, change the Browser Mode to IE9 mode, then try again it's fine. It appears like it's some kind of formatting issue with IE10.
Regards
Griff
Regards
Griff
Message 1 of 2
(852 Views)
1 REPLY 1
16-08-2013 3:59 PM
Hi Griff,
Try switching on compatibility mode.
Message 2 of 2
(367 Views)
