POP3 problems (2012-11-19) - SOLVED
RobDickson
Is anybody else having problems with POP3? IMAP seems OK.
I also had problems accessing the PlusNet website at about the same time, but that seems OK now.
Other websites seem OK.
4 REPLIES 4
Chris
Legend
Fixes: 169
Re: POP3 problems (2012-11-19)
Oldjim reported the same over on ThinkBroabdand, we hadn't seen anything here but are looking into it now.
Oldjim
Fixes: 63
Thread is here http://forums.thinkbroadband.com/plusnet/f/4181406-is-there-a-major-problem-with-plusnet-servers.htm... and this is from my router log
Note that this started after I first saw the problem - Plusnet have now posted a service notice
Mon, 2012-11-19 10:13:10 - LCP down.
Mon, 2012-11-19 10:13:12 - Initialize LCP.
Mon, 2012-11-19 10:13:12 - LCP is allowed to come up.
Mon, 2012-11-19 10:14:12 - Initialize LCP.
Mon, 2012-11-19 10:14:12 - LCP is allowed to come up.
Mon, 2012-11-19 10:14:13 - CHAP authentication success
Mon, 2012-11-19 10:14:22 - LCP down.
Mon, 2012-11-19 10:14:24 - Initialize LCP.
Mon, 2012-11-19 10:14:24 - LCP is allowed to come up.
Mon, 2012-11-19 10:14:27 - CHAP authentication success
chrispurvey
We've raised a problem(73411) and posted a <a href="http://usertools.plus.net/status/archive/1353321288.htm">service status</a>.
If you're having trouble either browsing web content and accessing internet applications or connecting then try logging into your router and disconnecting and then connect.
I'll post an update as soon as we have one.
RobDickson
Thanks. It seems OK now.
