Outlook receive timeout when using L2TP VPN
Perdrix
At home I use an OpenVPN pipe connected from my router, with I think an exception for plus.net.
I'm currently away from home, so I'm trying to use an L2TP VPN connection.  This seems to work for normal web browsing etc., but when I try to receive emails it just times out (even after increasing the timeout considerably).
Any suggestions on how to get this to work OK?
Thanks, Dave
10 REPLIES 10
idonno
Champion
Fixes: 6
Re: Outlook receive timeout when using L2TP VPN
Just a thought, have you got 'two-step verification' enabled? If so, you might need to set up a separate code on the device to receive Outlook e-mails.
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
Perdrix
This is using Outlook Office application not Outlook.com so I don't think "two step verification" applies.
Dave
Fixes: 160
Has this ever worked over the VPN?
You OP said "I THINK there is an exception for Plusnet" have you verified this?
Have you do any basic tests to see if you can 'reach' imap.plus.net over the VPN?
Try...
ping imap.plus.net
or...
tracert imap.plus.net
That should verify that DNS is being resolved and that there is a network path over the VPN to Plusnet services ... or that your exception is actually working.
Perdrix
I can't verify the router exception for plus.net as I can only access the router from inside my home network and I'm nowhere near home.   Just lets say the I'm pretty sure the it doesn't travel over the VPN when at home.
Pinging mail.plus.net gives me a timeout whether the connection is over the VPN or not (I don't use IMAP).
Thx, Dave
Fixes: 160
You will be using either IMAP or POP3 - it would be better to use the relevant server URL. imap.plus.net or pop3.plus.net
If ping is not working, then go a tracert to verify the connection path, as all Plusnet email servers respond to ping probes.
Perdrix
Ping to pop3.plus.net times out regardless of whether VPN is used or not.  Tracert in both cases over 20 hops.
Dave
Fixes: 160
Please post tracert results.
Perdrix
C:\Users\amonra>: No VPN
C:\Users\amonra>tracert pop3.plus.net
Tracing route to pop3.plus.net [212.159.8.81]
over a maximum of 30 hops:
  1     3 ms     1 ms     1 ms  BThomehub.home [192.168.1.254]
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4  1069 ms   824 ms   528 ms  217.41.216.125
  5   892 ms   944 ms   848 ms  212.140.235.54
  6  1359 ms  1242 ms  1238 ms  213.120.182.65
  7  1464 ms  1663 ms  1843 ms  31.55.164.107
  8   967 ms  1210 ms  1207 ms  109.159.248.69
  9  1284 ms  1174 ms   802 ms  core1-te0-3-0-15.ealing.ukcore.bt.net [109.159.248.28]
 10   762 ms  1640 ms  2076 ms  core3-te0-0-0-32.faraday.ukcore.bt.net [213.121.193.23]
 11     *        *        *     Request timed out.
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
C:\Users\amonra>: With VPN
  1    20 ms    21 ms    20 ms  10.1.1.1
  2   132 ms    29 ms    24 ms  88.202.231.2.static.midphase.com [88.202.231.2]
  3    62 ms    31 ms    21 ms  83.170.70.229
  4    21 ms    21 ms    21 ms  83.170.70.130
  5   237 ms    23 ms    21 ms  linx7.ukcore.bt.net [195.66.224.56]
  6   247 ms    25 ms    29 ms  host213-121-193-186.ukcore.bt.net [213.121.193.186]
 10     *        *        *     Request timed out.
Trace complete.
C:\Users\amonra>
Dave
Fixes: 160
Hi Dave,
Interesting results, which helpfully suggest that this problem is not within Plusnet's domain.
  1. You do not appear to be connected to Plusnet's network - the initial IP addresses are on BT's network
  2. The route is failing (in both cases) within BT.net core infrastructure - this looks like a peer routing issue
  3. *.plus.net is not excluded within your VPN set up
There have been some recent issues with accessing the POP3 servers due to load balancer issues - pop3.plus.net resolves to two IP addresses - the issue relates to one of the IP addresses not responding properly.  You could try tracert on the alternative IP address (highlighted in blue below), but I doubt it will make any difference.
PS C:\Users\Kevin> nslookup
Default Server:  dsldevice.lan
Address:  192.168.1.254
> pop3.plus.net
Non-authoritative answer:
Addresses:  212.159.8.81
          212.159.9.81
> exit
A tracert from a Plusnet connected PC looks like this...
PS C:\Users\Kevin> tracert pop3.plus.net
Tracing route to pop3.plus.net [212.159.9.81]
  1   272 ms     2 ms     2 ms  dsldevice.lan [192.168.1.254]
  2    33 ms    31 ms    30 ms  lo0.central10.psb-bng03.plus.net [195.166.130.254]
  3    40 ms    32 ms    32 ms  411.be7.psb-ir01.plus.net [84.93.253.115]
  4    38 ms    37 ms    37 ms  84-93-224-48.plus.net [84.93.224.48]
  5    38 ms    39 ms    38 ms  84-93-224-36.plus.net [84.93.224.36]
  6    48 ms    37 ms    40 ms  mail.plus.net [212.159.9.81]
Trace complete.
Perdrix
I clearly said at the start of this thread that I was away on holiday, so not on PlusNet network.
I still don't get why I can retrieve my mail when connected from the holday cottage without using the VPN (tracert the first) but if I turn the VPN on, then I can't (tracert the second).
Dave
