Outlook on the Web - Incoming emails not received
- Outlook on the Web - Incoming emails not received
15-11-2020 11:51 AM
I have tried to set up Outlook on the web to receive my plusnet acccount emails. Sending is working fine, but Incoming are not receiving. When I go into Outlook Sync settings the Username and password are not shown on the account each time.
I have set up
Incoming IMAP mail.plus.net and port 110 Authentication Basic , Encryp SSL
Outgoing relay.plus.net 465
Appreciate any help in sorting this
Re: Outlook on the Web - Incoming emails not received
15-11-2020 4:08 PM
15-11-2020 4:48 PM
Hi , I am trying to set up for my plusnet username emails to go through Outlook on the web, rather than Outlook 2019 on a PC.
Surely Plusnet can publish what settings to use.
15-11-2020 4:57 PM
They do. See here : https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/
15-11-2020 5:06 PM
Thanks John , Those are the settings I have used but they do not work.
15-11-2020 5:09 PM
@Robs55 What errors do you receive, if any?
Sorry I can't give detailed guidance - I don't use MS products.
15-11-2020 5:13 PM
Outlook receives an email with ;
- You
15-11-2020 5:18 PM
That's all greek to me - as I said, I don't use Microsoft mail clients, but I will try and point this to someone who will probably be able to help, if and when he's around.
@Townman ?
16-11-2020 7:20 AM
What are all the settings you’re using? Attach a screenshot showing them if it’s easier. Just make sure you redact any personal info
16-11-2020 7:41 AM
16-11-2020 8:11 AM
Having just re-read post #7 with a clear head, I have a feeling it may have been Outlook being slow to configure - note the date/time on there.
17-11-2020 2:47 AM
Frankly I would not be using any one service to harvest all of my mail from elsewhere. Aside from the risk of complex technical issues as reported here, one is courting the possibility of the failure of one email system inhibiting access to all email accounts.
Then there is the matter of sender IP address email submission rate limitation to inhibit denial of service attacks. All users of a service such this will ‘present’ as a single source for SMTP submission and might find sending fails further to the user collective having sent too many emails in the time period..
