Outlook on Android repeatedly "forgets" IMAP/SMTP passwords for PN email
paulh
So, new phone (Nokia 5.3, Android 10), Outlook mail client.
No problem setting it up & getting it to send/recv mail with PN email
EXCEPT
every couple of days, Outlook appears "forget" the PN passwords & repeatedly asks for them to be re-entered.
Not sure whether this is linked to Outlook updates, or some setting I have yet to discover (insecure mail ?)
Any thoughts?
5 REPLIES 5
Fixes: 160
Re: Outlook on Android repeatedly "forgets" IMAP/SMTP passwords for PN email
Is this over 4/5G? For just sending (SMTP)?
Much more likely to be a black listed IP address which an email client will report as a password failure when sending.
paulh
Nope, happens on 4G *and* when I'm at home on PN broadband over wireless.
Happened just now in fact.
Fixes: 160
Receiving AND sending?
All of the time or some of the time?
If just some of the time and for receiving then this is not an email issue, but one with either your phone or the email program you are using.
paulh
Everything you've asked is answered in my op
Fixes: 160
Go follow the response above then.
