Outlook IMAP on Android
the_groundsman
I'm trying to set up my plusnet email on the outlook android application. I put in the IMAP server details my plusnet username+mailbox and password. Unfortunately I can't seem to make a connectíon and am reluctantly using the gmail app. There doesn't seem to be a way of specifying ports or security settings.
Any advice?
6 REPLIES 6
bobpullen
Fixes: 316
Re: Outlook IMAP on Android
Not possible I'm afraid until we begin supporting SSL/TLS. The Android Outlook app was recently updated to only accept secured connections.
the_groundsman
richardvaughan
Hi bob
I understand is there any prospect of being able to use outlook on the iPad with an imap account in the near future?
Richard Vaughan
bobpullen
Fixes: 316
I've no experience of the iOS Outlook app Richard, but if it's the same as Android then it will only be possible when we get round to enabling SSL/TLS. I'd loveto give you a date for this but if you search the forums, you'll find it's a bit of a sour subject because we've been promising it for what seems like an eternity now Undecided
richardvaughan
Thank you I will keep my eyes open.  This variation seems to come with Office 365 which I installed on 1 Jan.  It seems that all modules are available for iPhone and iPad
R
Fixes: 160
@Bob,
You really do need to let the responsible team know how much embarrassment they have caused you....  Wink Cheesy Sad Crazy
Having been in the outbound trial for a year or so, I'm surprised that they have not yet got this live.
Kevin
