Outllook POP3 settings to use after migration to Greenby
CliveGray
Firstly a big thank you to all you guys on here as without you I don't think I would have worked things out.
Probably my main issue was that the login to the Greenby portal / webmail is username@username.f9.co.uk when we never used this, just our individual emails such as joe@username.f9.co.uk...
Anyway now I'm in I thought I should post my settings in case they are helpful for anyone else:
Incoming Mail:
Username = email address  e.g. joe@username.f9.co.uk
Password = your password as before
Server = mail.force9.net
Port = 995
This server requires an encrypted connection (SSL/TLS) should be ticked
Require logon using Secure Password Authentication (SPA) should not be ticked
Outgoing Mail:
Server = relay.force9.net
Port = 587
Encryption Method = None
My outgoing (SMTP) server requires authentication should be ticked
From the options below choose Use Same Settings as my incoming mail server
Hope this is useful for someone.
6 REPLIES 6
Fixes: 237
Re: Outllook POP3 settings to use after migration to Greenby
Two distinct logins
  • The Greenby user portal - that is the account name or DEFAULT email address
  • Webmail login - that is the email address
There is some room for confusion with these logins…
  • The Plusnet portal accepts CONTACT email address for the login (as well as the account-name)
  • Greenby appears to have morphed Force9 to f9 in various areas as the preferred domain name
  • There are hints that Plusnet’s current default mailbox address has been “enforced” during the migration giving rise account@account.f9.co.uk with an alias of the existing default mailbox name
There are outstanding question the latter point.
@dave  can clarification please be sought from Greenby on identity morphing?
mavison
@Townman Please can you clarify whaat you mean by default email address and mailbox?
On Plusnet...
  • I had a clearly marked default mailbox (the first one ever created). Is that what is also referred to as the 'primary' mailbox?
  • I was not aware of a default email address, though there is an email address shown in Account Details - mine is postmaster@<account>.f9.co.uk.
On Greenby...
  • No mailbox is marked as default.
  • I do not have an alias for <account>@<account>.f9.co.uk.
  • I do not have a mailbox with a name of <account>.
  • On the 'Team' page I am listed as the sole user,  with an email address of <account>@<account>.f9.co.uk (which I see is editable, though I have not tried to change it).
  • An email sent to <account>@<account>.f9.co.uk ends up in my catch-all mailbox ... which is not the one PN marked as default.
So what are my default email address and mailbox?
[PS Not sure why your post was relevant to Outlook and POP3!]
PhilipHeyes
The POP3 server has SSL/TLS enabled to correctly secure the credentials and email content.
So why is STARTTLS encryption not enabled for the SMTP server ?
This means the mobile and/or laptop will expose your credentials every time an email is sent.
mavison
@PhilipHeyes So why is STARTTLS encryption not enabled for the SMTP server ?
What makes you think it is not? I have been using StartTLS on relay.force9.net both before and after migration.
PhilipHeyes
Look at the proposed Outgoing Mail settings :
Outgoing Mail:
Port = 587
mavison
@PhilipHeyes Look at the proposed Outgoing Mail settings :
Yes, I saw that ... but I am looking at what I am using here without problems! And it includes StartTLS.
