Outgoing emails ipad
- Re: Outgoing emails ipad
04-11-2017 6:47 PM
I am a new Plusnet user, I am having problems setting up my outgoing emails. I am receiving emails but cannot seem to send out. I have tried everything but to no avail.
04-11-2017 6:52 PM
05-11-2017 2:44 PM
My broadband has been up and running for two weeks. I can receive emails but can not send out.
05-11-2017 9:09 PM - edited 06-11-2017 7:10 AM
Outgoing server relay.plus.net needs to be set up on port 587 without ssl and with authentication - use account-name and password.
Apple products try to force ssl.
05-11-2017 9:49 PM
Thank you, I have the settings as you say, I think it maybe something to do with changing my password. I did receive emails but now can neither receive or send. I have entered the correct settings and am now at a loss.
05-11-2017 10:28 PM
To check you are using the correct username and password I suggest trying Webmail https://webmail.plus.net . For the default mailbox the username and password should be the same as you use to log into the Member Centre on the website.
06-11-2017 8:01 AM
Thank You. I think the problem is because I changed my password. My user name and password are the same as my account but I ve seen where it says you have to also change the router password. I am not very technical and I don’t know all the places I need to change passwords to match my new one.
06-11-2017 1:51 PM
06-11-2017 2:28 PM
I can now get incoming emails but still can not send out.
The error messages say:
Cannot connect to the Outgoing Mail Server my user name @smpt.relay.plus.net
The second one says:
The connection to the outgoing server smpt.relay.plus.net failed.
Any advice will be appreciated.
06-11-2017 5:28 PM
Unless you've made a typo in your post, you have the outgoing server wrong. It should be relay.plus.net
06-11-2017 9:29 PM
Thank You. I am also having the same problem setting up an extra email address for my husband. Can you help.
06-11-2017 11:19 PM
Additional mailboxes are created using the Manage My Mail tool in Member Centre. The email address for additional mailboxes is of the form
mailboxname@accountname.plus.com
The username for accessing and sending mail from these additional mailboxes needs to be of the form
accountname+mailboxname
with the password set when the additional mailbox was created..
Other settings should be the same as those used with the default mailbox.
Please post details if using these settings gives an error message.
07-11-2017 11:56 AM
The advice from @spraxyt is correct, the settings for additional mailboxes need to be entered in that exact format otherwise you'll receive errors.
