Outgoing emails ipad
carolroberts5
I am a new Plusnet user, I am having problems setting up my outgoing emails. I am receiving emails but cannot seem to send out. I have tried everything but to no avail.
12 REPLIES 12
Browni
Aspiring Hero
Fixes: 60
Re: Outgoing emails ipad
Is your broadband up and running yet? That needs to be active before being able to send through Plusnet's mail servers.
carolroberts5
My broadband has been up and running for two weeks. I can receive emails but can not send out.
Fixes: 160
What error message do you receive?
Outgoing server relay.plus.net needs to be set up on port 587 without ssl and with authentication - use account-name and password.
Apple products try to force ssl.
carolroberts5
Thank you, I have the settings as you say, I think it maybe something to do with changing my password. I did receive emails but now can neither receive or send. I have entered the correct settings and am now at a loss.
spraxyt
Resting Legend
Fixes: 75
To check you are using the correct username and password I suggest trying Webmail https://webmail.plus.net . For the default mailbox the username and password should be the same as you use to log into the Member Centre on the website.
David
carolroberts5
Thank You. I think the problem is because I changed my password. My user name and password are the same as my account but I ve seen where it says you have to also change the router password. I am not very technical and I don’t know all the places I need to change passwords to match my new one.
Fixes: 160
If the account / router password were wrong you would likely encounter issues connecting to the internet ... full stop.
carolroberts5
I can now get incoming emails but still can not send out.
The error messages say:
Cannot connect to the Outgoing Mail Server my user name @smpt.relay.plus.net
The second one says:
The connection to the outgoing server smpt.relay.plus.net failed.
Any advice will be appreciated.
Fixes: 393
Unless you've made a typo in your post, you have the outgoing server wrong. It should be relay.plus.net
carolroberts5
Thank You. I am also having the same problem setting up an extra email address for my husband. Can you help.
spraxyt
Resting Legend
Fixes: 75
Additional mailboxes are created using the Manage My Mail tool in Member Centre. The email address for additional mailboxes is of the form
mailboxname@accountname.plus.com
The username for accessing and sending mail from these additional mailboxes needs to be of the form
accountname+mailboxname
with the password set when the additional mailbox was created..
Other settings should be the same as those used with the default mailbox.
Please post details if using these settings gives an error message.
David
Chris
Legend
Fixes: 169
The advice from @spraxyt is correct, the settings for additional mailboxes need to be entered in that exact format otherwise you'll receive errors.
