On Holiday. Email Problems
- Re: On Holiday. Email Problems
19-09-2015 4:29 AM
However, I also managed to get plenty of emails which will not go. Even if I send the emails to myself.
The inconsistency is very confusing.
I get the following error messages:
The message could not be sent. The setting for your outgoing email [SMTP] server might need to be configured. To find the server settings for 'XXX@YYY.plus.com', please contact your email service provider.
Subject 'test'
Server Error: 452
Server Response: 452 Too many rcpts in time period from this IP
Server: 'relay.plus.net'
Windows Live Mail Error ID: 0x800CCC79
Protocol: SMTP
Port: 587
Secure(SSL): No
Can anyone suggest a solution?
Steve
19-09-2015 2:07 PM
Use the same credentials (user name & password) as used for the IMAP / POP3 server.
19-09-2015 2:50 PM
I finally managed to send some emails by swapping the port number between 25 and 587.
It won't reliably send email on either 25 or 587, but it seems to allow some messages to be sent when I first change from 25 to 587.
Very flaky indeed!
19-09-2015 3:33 PM
If you are able, try telnet to relay.plus.net on port 25 & 587
19-09-2015 9:41 PM
Downloaded the client. Started the client and typed "o relay.plus.net 25" I got ": connect failed"
When I tried "o relay.plus.net 587" I got "220 avasout06 smtp relay.plus.net" I assume this is a connection?
Simple messages seem to send OK. Multiple addressees and pictures are difficult!
20-09-2015 8:25 AM
20-09-2015 9:49 AM
Sounds like you may be falling foul of that...
21-09-2015 2:08 AM
Doesn't matter now - we go home tomorrow.
Thanks to all for the help and advice.
