Odd email problem.
- Odd email problem.
Odd email problem.
26-11-2014 7:43 PM
For some unknown reason mail is now arriving in between older email that has already been read.
Not sure if this is some error on my part but would be grateful for advice on a fix for this problem.
To give a more clearer example I might have 4 previously opened older emails then one new email appears under that one with the current date then 5 or 6 older opened email then a further one or two new emails.
In short I have to check my whole email box for new emails that could be anywhere.
Re: Odd email problem.
26-11-2014 7:57 PM
26-11-2014 8:52 PM
27-11-2014 4:07 PM
I have 2 email programs, one is Gmail that works fine with no problem and the other one is Plusnet email which is the one I am having this odd problem with.
Quote from: HPsauce This might seem a silly question, but what program do you run to look at your emails and on what device/operating system?
I am using a desktop computer running Linux Mint 17 although I sometimes access my email using a Samsung tablet.
PeeGee,
Not sure about the sort field, didn't even know there was one but that sounds like a logical explaniation although I do not recall making any type of alterations in the settings, will certainly look into that.
27-11-2014 4:21 PM
Those are email SERVICES, not programs. To get pedantic, what do you RUN or CLICK ON to access your Plusnet email?.
Quote from: gleneagles I have 2 email programs, one is Gmail that works fine with no problem and the other one is Plusnet email
27-11-2014 4:26 PM
27-11-2014 5:08 PM
e.g. Are you going to a PlusNet mail interface (webmail?) or via another service (there are loads, even Gmail will do it) that accesses your PN mailbox for you? Post the URL you use here.
If it's PN webmail I never use that so can't advise, but others presumably will.
27-11-2014 5:35 PM
Hope this is the info you need.
27-11-2014 5:44 PM
I believe the PN webmail allows you to sort on any of the columns, hopefully someone who uses it can advise, but usually the convention is that you just click on the relevant column heading.
Quote from: PeeGee So, what field are you sorting on - title, sender.....?
27-11-2014 6:04 PM
28-11-2014 2:24 PM
Fortunately I only use webmail for a few things so it's not a major problem but just out of interest is it possible to delete or change this mail box and start from scratch again, I accept everything in my webmail in box would be lost ?
28-11-2014 2:32 PM
Apologies if this has been worded badly but I think you can see what I am trying to ask.
28-11-2014 2:40 PM
The webmail interface is very simple - If you click on 'Date' as per kmilburn's screengab, the email will sorted by date. Each time you click on Date the display will toggle between oldest or newest received being first.
If this doesn't fix it, click on the icon to the left of 'Subject' and make sure that 'List' is selected and not 'Thread'. Save any changes to clear the popup window.
HTH
28-11-2014 4:36 PM
The last couple of emails that came through appeared at the top of the list but I will need to give it a few days to be sure it's ok but that's wishful thinking as all settings/options were set as expected.
