Odd bounce error message
- Re: Odd bounce error message
22-10-2011 7:32 PM
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
<submit.plS4QPJlo4Fy83p2@spam.spamcop.net>: host relay.plus.net[212.159.8.107]
said: 552 nuQE1h0030mutzo01uQFoe message rejected due to spam or virus. If
you believe this is in error please login to your portal or contact your
ISP support team. (in reply to end of DATA command)
--97741A4A5FD.1319307856/tty.org.uk
Content-Description: Delivery report
Content-Type: message/delivery-status
Reporting-MTA: dns; tty.org.uk
X-Postfix-Queue-ID: 97741A4A5FD
X-Postfix-Sender: rfc822; steve@tty.org.uk
Arrival-Date: Sat, 22 Oct 2011 19:24:14 +0100 (BST)
Final-Recipient: rfc822; submit.plS4QPJlo4Fy83p2@spam.spamcop.net
Original-Recipient: rfc822;submit.plS4QPJlo4Fy83p2@spam.spamcop.net
Action: failed
Status: 5.0.0
Remote-MTA: dns; relay.plus.net
Diagnostic-Code: smtp; 552 nuQE1h0030mutzo01uQFoe message rejected due to spam
or virus. If you believe this is in error please login to your portal or
contact your ISP support team.
Content-Description: Undelivered Message
Content-Type: message/rfc822
Content-Transfer-Encoding: 8bit
So I'm not sure where it got bounced but I suspect its the PN spam system thinking my attached files, which contain spam emails,, which I'm forwarding to Spamcop are in fact spam which would be pretty stupid as it allowed them (about 17 since lunch time) to get through to me in the first place. This happened before with IronPort but someone at PN fixed it.
Edited to add : its PN doing it. I commented out the relay-host line in my postfix config and all the emails went through fine.
22-10-2011 11:35 PM
Obviously Cloudmark Authority perceives your server as an originator of spam, but the original source is not seen that way.
22-10-2011 11:44 PM
So right now I'm getting spam but have no way of reporting it..... typical!
23-10-2011 12:43 AM
23-10-2011 9:45 AM
23-10-2011 12:03 PM
What isn't clear to me is whether Cloudmark fails to identify these messages as spam on their way in?
23-10-2011 12:31 PM
23-10-2011 2:37 PM
Since you use the relays outbound obviously that path is affected and whitelisting of messages to Spamcop is needed on Cloudmark.
23-10-2011 2:48 PM
23-10-2011 3:02 PM
[tt]Received: from relay.ptn-ipout02.plus.net (relay.ptn-ipout02.plus.net [212.159.7.36])
(using TLSv1 with cipher RC4-SHA (128/128 bits))
(No client certificate requested)
by tty.org.uk (Postfix) with ESMTPS id 98476A4A15D
for <xxx@xxxxxxuid.plus.com>; Fri, 14 Oct 2011 12:15:36 +0100 (BST)
X-IronPort-Anti-Spam-Filtered: true
X-IronPort-Anti-Spam-Result: AtcNAJsZmE7VomGh/2dsb2JhbAApGoJNgiUDnDGBZoRbd4EFgVMBAQQEIB0DAQIIAyMGAQUKFxgTAQkCAjEsCAcEARQEAQMEh10CBiSkJgFngyuBTYx2AQWGWYEUk3uFR4wq
Received: from unknown (HELO mail.just-the-name.co.uk) ([213.162.97.161])
by relay.ptn-ipout02.plus.net with ESMTP; 14 Oct 2011 12:15:35 +0100
Received: from mail49.us1.mcsv.net (mail49.us1.mcsv.net [204.232.163.49])
by mail.just-the-name.co.uk (Postfix) with ESMTP id D2393BA458
for <sxx@xxxxxorg.uk>; Fri, 14 Oct 2011 12:15:32 +0100 (BST)[/tt]
[tt]
Now its going:
Received: from relay.pcl-ipout01.plus.net (relay.pcl-ipout01.plus.net [212.159.7.99])
by tty.org.uk (Postfix) with ESMTPS id D72BFA4ACE9
for <x@pexxxxxxxuid.plus.com>; Sun, 23 Oct 2011 12:56:14 +0100 (BST)
by relay.pcl-ipout01.plus.net with ESMTP; 23 Oct 2011 12:56:14 +0100
Received: from mailc-ba.linkedin.com (mailc-ba.linkedin.com [216.52.242.152])
by mail.just-the-name.co.uk (Postfix) with ESMTP id 678C4BBEA2
for <xxxx@xorg.uk>; Sun, 23 Oct 2011 12:56:06 +0100 (BST)
DomainKey-Signature: q=dns; a=rsa-sha1; c=nofws;[/tt]
In the first one you can clearly see the ironport check results
23-10-2011 8:29 PM
24-10-2011 11:49 AM
I sent a read receipt for a message that had just arrived - and it bounced!
Now I'm not too well up on computer-speak, could someone please translate?
The following message to <xxxxxxxx@supanet.com> was undeliverable.
The reason for the problem:
5.1.0 - Unknown address error 550-'Callback setup failed while verifying <yyyyyyy@zzzzzzz.plus.com>\nCalled: 212.159.8.200\nSent: MAIL FROM:<>\nResponse: 550 IP is DNSBL listed - http://www.spamhaus.org/query/bl?ip=213.40.66.38\nThe initial connection, or a HELO or MAIL FROM:<> command was\nrejected. Refusing MAIL FROM:<> does not help fight spam, disregards\nRFC requirements, and stops you from receiving standard bounce\nmessages. This host does not accept mail from domains whose servers\nrefuse bounces.\nYour return address <yyyyyyy@zzzzzzz.plus.com> does not appear to be\nvalid. Sender verify failed.\nMon, 24 Oct 2011 11:26:08 +0100 on host 213.40.66.38'
I am not invalid!!!
Here's the headers off the bounce message:
X-MSK: CML=1.402000
Return-path: <>
Envelope-to: yyyyyyy@zzzzzzz.plus.com
Delivery-date: Mon, 24 Oct 2011 11:26:12 +0100
Received: from [212.159.8.109] (helo=avasin13)
by inmx19.plus.net with esmtp (PlusNet MXCore v2.00) id 1RIHjM-0004pA-Tw
for yyyyyyy@zzzzzzz.plus.com; Mon, 24 Oct 2011 11:26:08 +0100
Received: from relay.pcl-ipout02.plus.net ([212.159.7.100])
by avasin13 with Plusnet Cloudmark Gateway
id oaS81h00729VYaU01aS8Y2; Mon, 24 Oct 2011 11:26:08 +0100
X-CM-Score: 0.00
X-CNFS-Analysis: v=2.0 cv=O967TWBW c=1 sm=1 a=MOoU6_y5KB8A:10
a=wPDyFdB5xvgA:10 a=d185jZcJAAAA:8 a=EBOSESyhAAAA:8 a=oxtLoEQ2AAAA:8
a=BHGZfj7sxUW_McQwjpgA:9 a=9uvm6SlqeZPP25rv8HkA:7 a=CjuIK1q_8ugA:10
a=Q-yGKnO_R9AA:10 a=uBK8OgW28t_2rpQX:21 a=tTmV_vZD5Pi1On8Q:21
a=0Bzu9jTXAAAA:8 a=Fy-wCSNV4vN1d1oKViQA:7 a=znHlCSW7yks-vR_v:21
a=AIoYtGQSql7Cs4UR:21 a=FLMvxEwcbGxyaG4-TV0A:9 a=TFbchNSdzUL2fcWXfy6y5g==:117
Message-Id: <0a85c0$69s0st@pcl-ipout02.plus.net>
Received: from localhost by relay.pcl-ipout02.plus.net;
Date: 24 Oct 2011 11:26:08 +0100
To: yyyyyyy@zzzzzzz.plus.com
From: "Mail Delivery System" <MAILER-DAEMON@relay.pcl-ipout02.plus.net>
MIME-Version: 1.0
Content-Type: multipart/report; report-type=delivery-status; boundary="CdWDw.4i0ZPuUAz.tzDfn.2Z6ZhMs"
X-PN-Virus-Filtered: by PlusNet MXCore (v5.00)
X-PN-Spam-Filtered: by PlusNet MXCore (v5.00)
Subject: Delivery Status Notification (Failure)
25-10-2011 7:52 PM
26-10-2011 4:54 PM
Quote from: SteveA But what pees me off is that spam is coming in via PN and is NOT being recognised as spam but when I try to report it as spam PN's wonderful spam system identifies it as spam.
Should now be sorted as per my post here.
Quote from: Tigger The following message to <xxxxxxxx@supanet.com> was undeliverable.
I may be wrong but I /think/ the read receipt was sent via our servers and the recipient server (Supanet - 213.40.66.38) tried a sender-verify call on your email address <yyyyyyy@zzzzzzz.plus.com>. This involves connecting to the primary MX record for zzzzzzz.plus.com and attempting an SMTP transaction as follows:
HELO <verifier host name>
MAIL FROM:<>
RCPT TO:<the address to be tested>
QUIT
The primary MX record for zzzzzzz.plus.com is likely to be mx-trial.core.plus.net (cloudmark) at the time of writing. I reckon when Supanet's servers tried connecting to ours cloudmark rejected the attempt because of:
So our inbound mail server failed the sender-verify check because Supanet's server was listed on one of Spanhaus' blacklists (although it doesn't seem to be now). Would be interested to know if this happens again?
