Not receiving from btinternet addresses.
PhyllisTyne
My mate has PN and has noticed he is not getting certain emails. He narrowed it down to all his contacts who are btinternet users.
He uses pop3 on a mac with items left on server which he accesses from other mobile devices using imap.
Interestingly he once saw a notification on his android device that he had a message from one of these people but when he tried to open it, it wasn't there.
The only thing I can think of is his mac is deleting them off the server for some reason but it seems a  bit odd it only does it for btinternet addresses.
The messages are nowhere to be seen. Not in deleted or trash folders on any device or webmail!
Anyone any idea why this might be happening and how he might sort it out?
TIA
PT
2 REPLIES 2
Fixes: 143
Re: Not receiving from btinternet addresses.
The first thing I'd recommend is to get rid of the POP3 fly in the ointment.  If accessing the same email address on multiple devices is a requirement, they all ought to be IMAP.
Also check spam filter configuration under email settings on the user portal - check the black list entries.
PhyllisTyne
Thanks, looked in to all that to no avail. One of his 'blocked' senders sent to me and it came through fine. At a bit of a loss now.
PT
