Not receiving emails
AlanP
Hi. I have set up email account on new ipad. I have received emails only from plusnet about billing etc. No other emails received. I can send emails ok. Replies to those emails are not received. Checking on webmail, emails are received....but not the plus net billings ones? I've tried imap and pop settings...no joy. Any help is appreciated.
6 REPLIES 6
Strat
Fixes: 565
Re: Not receiving emails
Moderators Note
This topic has been moved from Tech Help to Email.
Fixes: 151
If the iPad set up the account (use imap) with no errors, try setting the root folder to inbox
Thrall
Seasoned Pro
Fixes: 23
I suspect the mailbox isn’t set up correctly on your iPad. Plusnet will send billing emails to postmaster@ which means they’ll send them to every Plusnet mailbox associated on an account.
How many Plusnet mailboxes do you have? When setting up the mailbox you want on your iPad, are you using the correct username?
For example the default mailbox would use the account username but a secondary mailbox would be username+mailbox
Although this doesn’t explain why you don’t see the billing emails on webmail... at the top right it’ll show you your email address, is that the correct one as expected?
Fixes: 151
That is not correct - billing emails are not sent to every mailbox. They are sent to the default mailbox and (if different) the account contact email address.
Some users set up email addresses such as him@ her@ and never look at the default mailbox then wonder why they do not “receive” account notices.
AlanP
Thanks for reply.
I have found some new information which may help to find the solution.
Ipad email account created using full email address   ****@username.plus.com.   I get emails only from plusnet.
If I log into webmail with ****@username.plus.com, I get all emails, but not plusnet.
If I log into web mail with username only, then I get plusnet email only
Not sure how things have got confused?
Fixes: 151
If you want to access the default mail box, the userID is youraccountname with the account password
If you want to access a secondary mail box the userID is youraccountname+mailboxname with the mailbox password
