New mail box problem
Mav
Fixes: 515
I created a new mail box around 2 hours ago. After entering the password and it's confirmation then clicking next the page just seemed to get stuck although I did get several emails to indicate all was Ok and the box should be available within 30 minutes.
I constantly get the box requesting I eneter the user details for this mail box (but no others) when using Outlook yet the mail box does appear in the list within the portal.
Can I assume that the creation didn't go according to plan and simply delete and recreate the box or should I wait a while longer?
Forum Moderator and Customer
4 REPLIES 4
jelv
Fixes: 10
Re: New mail box problem
Can you access it via webmail?
If you can I suggest you check the Outlook settings - especially security related.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Mav
Fixes: 515
Thanks Jelv.
Doh! Sometime one can't see the wood for the trees. I had made a typo and put mail.pius.net rather than mail.plus.net. Not any easy one to spot Cool
jelv
Fixes: 10
Glad to have heiped!
Mav
Fixes: 515
How come I spotted that one straight away  Cheesy
