New folder problem with Plusnet imap and ipad
- New folder problem with Plusnet imap and ipad
05-04-2015 6:36 PM
A family member tried to the same with her plusnet IMAP mail and an error ' unable to create mailbox on server" appears. So I tried it usng my Plusnet email and I get the same error!
All we are trying to do is add a sub folder(s) to avoid having one massive in box with no 'filing/ grouping' of mails which is rather unwieldy.
Is there some restriction on Plusnet Imap to stop us adding folders or is there another way of doing this?
Many thanks in anticipation,
Graham.
Re: New folder problem with Plusnet imap and ipad
05-04-2015 8:29 PM
The quickest way to add a folder is to use the webmail interface accessed here https://webmail.plus.net
05-04-2015 8:44 PM
Can you please describe very clearly what you have configured and what you are trying to achieve?
I have my emailbox configured for IMAP operation on my PC (using Outlook 2010), my iPhone and iPad.
I have just created a new folder "Test Folder" on the PC. In the time it took me to pick up my phone, unlock it and open the mail box on there, the folder was visible on the iPhone.
Check that all IMAP configurations are identical - using authentication and port 587.
Kevin
05-04-2015 8:52 PM
06-04-2015 8:22 AM
As RPM says I have an IMPAP plusnet email setup. What I want is to be able to do add extra folder(s) from my my ipad.
My IMAP server settings are set up with correct port no.s as you describe.
In the Ipad you go into mail, the plusnet account, select "edit", then "new mailbox" (I.e. new IMAP folder), enter then name and then "save".,, that's when the error occurs.
I discovered that If you go into plusnet webmail and create the folder there it works, but that's far more clunky.
With my waitrose mail, I can do what I described above and it works.
06-04-2015 10:12 AM
We rather need Bob Pullen on this one.
There is wide spread comment about this Apple functionality not working across the Internet, however you are finding that it works on the Waitrose IMAPservices (Plusnet provided) but not the naked PlusNET IMAP servers. So there must be some difference; though even if it is identifiable, it might not be alter able.
Kevin
06-04-2015 10:22 AM
See this for info
Actually, try removing the INBOX prefix...
06-04-2015 10:30 AM
06-04-2015 12:16 PM
Many thanks for all your help - very much appreciated.
Graham.
06-04-2015 12:29 PM
06-04-2015 1:06 PM
07-04-2015 9:37 AM
Hitherto the only apparent difference this has made (in Outlook 2010) is to alter the presentation of the Sent / Draft / Trash folders between appearing as peer to or sub folders of the Inbox. In other words it has not appeared to be overly important.
Why does it make a difference here between the Waitrose servers and the PlusNET servers?
08-04-2015 9:53 AM
Quote from: Townman Why does it make a difference here between the Waitrose servers and the PlusNET servers?
Plusnet uses the default namespace configuration convention for the software we're using - INBOX. Because of this, all special folders, like Sent, Drafts etc., are created as sub-directories of the main Inbox. If you try to create a new IMAP folder at the same level as the Inbox then this will fail as it is not permitted.
Some clients will handle this gracefully, others require extra configuration (as we've found here).
Waitrose is the product of our acquisition of Brightview/Madasafish back in 2007. Whilst the back-end server relies on the same software these days, it didn't before we integrated the platform and the namespace works slightly differently. Instead of special folders being sub-directories, they sit at the same level as the main Inbox. When we migrated customers to Plusnet's email platform, we preserved this behaviour to avoid complications.
08-04-2015 10:00 AM
Thanks for that.
So to be precise, when configuring an IMAP client against the PlusNET servers, one ought to specify the path prefix as INBOX rather than leaving it blank?
08-04-2015 10:02 AM
http://www.plus.net/support/email/setup/ios-setup.shtml
