Mozillat Tunderbird not working after virus cleanup
hamilton36
I had a nasty Trojan and a few other viruses, which I managed to clean up with Stopzilla.  Now I find that Mozilla Thundebird, which is my default email, does not work. It cannot connect to Plusnet and I have not changed any settings from the time it worked.  Surprizingly, Outlook Express works.
Is it possible that you blocked me when I  had the virus?  I have checked all the email settings and they are OK.
Can you help, please.
Thanks,
Alex
5 REPLIES 5
orbrey
Re: Mozillat Tunderbird not working after virus cleanup
More likely that something in the thunderbird profile has been corrupted or moved by either the virus or its subsequent removal. I suspect if you delete the profile and create a new one it'll sort things out for you.
hamilton36
I will try that Matt, but I think that the more likely problem is that your website in not responding.  Quite often it times out several times before I get it. Really frustrating.  I also get regular "no response" on my mobile when downloading emails.
Good try, but I think you really need to look at your service!
Thanks,
Alex
dick:quote
spraxyt
Aspiring Legend
Fixes: 75
I've had no problems whatsoever using Thunderbird with the new spam appliances, albeit using the Force9 servers and IMAP in my case.
David
hamilton36
Quote from: hamilton36
Thanks,
Alex
Huge apology Mat. My router has packed up, nothing wrong with your service.
Alex
bobpullen
Fixes: 314
I'm sure Matt won't mind! Wink
Glad to hear that you've identified the problem anyway Smiley
