Maximum Group Size for sending
- Re: Maximum Group Size for sending
19-04-2010 4:23 PM
Is this a Plusnet limit or something Microsoft have done
20-04-2010 2:43 PM
20-04-2010 2:52 PM
I can't find any restriction in Outlook Express - could it be an Ironport problem now that outgoing emails apparently go through it
20-04-2010 3:08 PM
So yes, it seems to be set on our side, mainly to avoid spam.
20-04-2010 3:11 PM
Perhaps that should be added to a FAQ somewhere as 30 isn't a very large number for a group mailing list
I assume that incoming mail is mail coming into your servers from customers using relay.plus.net
23-04-2010 7:20 PM
23-04-2010 7:36 PM
The error was a bit odd.
It was something on the lines of one of the addresses being incorrect. The odd thing is that normally when you get that error it sends it to the rest of the recipients but in this case it wouldn't send any at all.
23-04-2010 7:46 PM
