Max number of addresses in one email?
- Re: Max number of addresses in one email?
19-08-2011 12:27 AM
My wife has just taken over as secretary of a church group.
She'll need to send a quarterly email to approx 80 people.
Is there a limit on the number of addresses in one email?
Current secretary is with Tiscali which apparently has a limit of 30, so has to send 3 emails to 3 different address lists.
Understandable anti-spam measure but annoying nevertheless.
Martin
Martin
Message 1 of 8
(2,085 Views)
7 REPLIES 7
19-08-2011 12:22 PM
As far as I know Plusnet don't limit the number of addressees, however they do use tarpitting to slow down message delivery for long recipient lists. Details of tarpitting can be found here.
Would using a restricted Google Group simplify the quarterly task of emailing members and handle secretary changes more conveniently? Parts of this Community Support Library article provide background to using such a group.
David
Message 2 of 8
(694 Views)
19-08-2011 10:32 PM
Thanks, most helpful.
I suspect even registering for Google groups would be beyond many of the recipients , although I think that can be bypassed?
EDIT: the option to "add members directly" was removed in July this year, so no it can't be bypassed,
Lengthy delay in email delivery might be OK.
Is the delay increase linear, ie should I assume around 1 minute delay for 80 people?
Message 3 of 8
(694 Views)
20-08-2011 12:51 AM
I imagine the delay increases non-linearly, could perhaps be 2 or 3 minutes for 80 addressees which might mean several hours to complete sending - however I think that is after arrival on the server.
Thanks for mentioning it is no longer possible to add members directly to Google Groups. I'll add a note to that effect in the article.
David
Message 4 of 8
(694 Views)
20-08-2011 2:38 PM
Quote from: spraxyt I imagine the delay increases non-linearly, could perhaps be 2 or 3 minutes for 80 addressees which might mean several hours to complete sending - however I think that is after arrival on the server.
If its after arrival on the server then no problem at all.
It wouldn't matter if it took even a couple of days to arriive, so long as we know it will get there eventually.
I'll raise a ticket to confirm.
Thanks again.
Message 5 of 8
(694 Views)
20-08-2011 3:14 PM
One way out of the problem - which we use - is to split the mailing list into 4 and send four separate emails (using the BCC option of course)
Message 6 of 8
(694 Views)
16-09-2011 1:06 PM
.. I created a Google group (60 people) for such a thing...
... I was wondering what happened with that.. was looking all over wondering why I couldn't
Quote from: m063 EDIT: the option to "add members directly" was removed in July this year, so no it can't be bypassed,
Message 7 of 8
(694 Views)
20-09-2011 2:47 PM
IME you'll not have any problems sending an email to 80 recipients using our relay servers.
Message 8 of 8
(694 Views)
