Mailbox too large
- Mailbox too large
Mailbox too large
02-10-2013 3:02 PM
Just had a warning from PN that one of my mailboxes has exceeded the 1GB limit. I have quite a few mailboxes. Is there any easy way to tell which is the guilty one?
PT
PT
Message 1 of 6
(1,169 Views)
5 REPLIES 5
Re: Mailbox too large
02-10-2013 8:30 PM
Hey there,
You'll need to reply to the support ticket asking for a breakdown. It's not something that you can easily see straight off.
However, if you have some time on your hands, you can log into the webmail at http://webmail.plus.net
Go to Personal Settings -> Folders (Tab) -> select a folder on the left hand side, then at the bottom on the right hand side, click "Click to get folder size"
Hope this helps,
Matt
Hope this helps,
Matt
Message 2 of 6
(445 Views)
02-10-2013 8:42 PM
Thanks, been in there and had a look at what I thought might be guilty boxes but nothing over 500mb when adding all folders together. I assume they are referring to an individual mailbox and not the size of all of my boxes added together. The do refer to "one or more of your mailboxes has become very large ".
I have asked them to give me a clue in a response to the ticket.
PT
PT
Message 3 of 6
(445 Views)
02-10-2013 8:53 PM
Cool Cool, It's a generic message that gets sent out.
And they're talking about the collective, 1GB across all mailboxes.
Message 4 of 6
(445 Views)
02-10-2013 9:00 PM
If its 1GB total that would explain it - time to go in and do some housekeeping!
Message 5 of 6
(445 Views)
02-10-2013 9:37 PM
A while back, I had a warning from PN that one, or more of my mailboxes had not been accessed for a while, and would be removed in short notice ( a month I think )
Message 6 of 6
(445 Views)
