Mailbox disk space management via member centre
cjags
Fixes: 4
Using the email settings part of the member centre I can see a list of mailboxes and can add/delete/create.
But is there anywhere I can see how much disk space each mailbox is taking up?
5 REPLIES 5
jelv
Fixes: 10
Re: Mailbox disk space management via member centre
Nope - you have to check using either your email client or by using webmail.
Edit: Using webmail - click the cogwheel at the bottom left hand corner and select manage folders. After selecting a folder there's a link to get it's size. You have to do this for every folder and add them up!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
cjags
Fixes: 4
Quote from: spoon
I think I will pass on that one.  Undecided
Fixes: 162
If you are over your allowance, you can reply to the ticket and request a report of mailbox sizes.
southerner
I've been using this to keep an eye on my IMAP folder sizes. It also does incremental local backups of your data http://www.broobles.com/imapsize/imap-backup.php
cjags
Fixes: 4
Quote from: woodm
Cool.
I will give that a go.
Many thanks.
