Mail set up on iPhone and iPad only send from gmail and not madasafish
- Re: Mail set up on iPhone and iPad only send from ...
31-10-2015 7:36 PM
Have set up two email accounts one for my gmail and the other my madasafish. They both deliver incoming mail but I can only send or forward mail from my gmail account.
The setting for the madasafish mail is
Incoming mail server: pop.madasafish.com
Username : my correct usernam
Password: my correct password
Outgoing
SMTP
SMTP.madasafish.com
It is my primary SMTP server and is switched on.
My teccie friends cannot sort it out. Any ideas please?
When I try to send mail from madasafish account it just sits in the outbox for hours until I delete it.
Outgoing
SMTP
SMTP.madasafish.com
Message 1 of 4
(1,181 Views)
3 REPLIES 3
Re: Mail set up on iPhone and iPad only send from gmail and not madasafish
02-11-2015 12:25 PM
What Internet connection are you using when trying to send your messages?
If you're not using your Plusnet/Madasafish broadband account, and are relying on mobile data instead, then you'll need to use a username/password for sending email too. This should be your full email address and usual password. Any option for SSL/TLS/Secure connectivity will need disabling.
I've checked your account and it's working as expected, so that points to something to do with your settings.
Message 2 of 4
(873 Views)
02-11-2015 1:47 PM
Ah thankyou
I just disabled SSL and successfully sent 2 emails to my gmail account.
Maybe you could answer the other query that I raised.
On Saturday I got a message saying my IMAP quota was exceeded but I havent a clue what this means.
Also, when was with MAAF if I had gone over my madasafish webmail allowance I could log into MAAF webmail and tidy up the folders. WIl I still have to do this and, if so, how do I log in to webmail now?
Message 3 of 4
(873 Views)
02-11-2015 1:55 PM
Ignore the end of my last message. The webmail has been sorted out on another thread.
This is a great forum now that I understand how to use it.
Message 4 of 4
(873 Views)
