Mail redirection
- Mail redirection
Re: Mail redirection
02-06-2011 1:41 PM
Quote Thank you for your query.
I can see from your account that these are currently pending, i have refreshed the component and these are now active.
Hope this helps.
and they are now working.
Does this solution help in identifying the underlying problem
02-06-2011 1:48 PM
Quote from: jelv Bob,
Please have a look at the email sitting in my default mailbox (which is a different mailbox to my catchall). The email address it was sent to is supposed to redirect to gmail.
I'd love to know how that happened.
I'll leave my redirection test alone for you to investigate. Test 1 seemed to create OK.
Thanks, I've collated some useful info from your account. It seems that under the condition we've identified, where redirects are created with null destinations in the maildb, they bizarrely route to the default mailbox on the account!
Quote from: digital
Quote from: Bob If you have a mailbox that's marked as pending then I'm assured it should work, however even if it does post here anyway as I'd like to see if I can remove the pending flag from this side as per Bud's other post here.
Hi Bob. Two for your attention at username spinningweb.
Thanks, have performed some jiggery-pokery that I reckon should have removed the pending flag?
Quote from: A I don't use any black-holing, my redirects to gmail end up in postmaster.
Looking at your account the symptoms are the same as the ones jelv has been reporting. More concerning though (which is also the case with one of jelv's redirects), some of these broken entries *don't* show as 'pending' in the MMM interface!
Quote from: Oldjim reply received
Hope this helps.
Well we've tried it on other accounts and it hasn't worked. Happy to try the same on @jelv's and @A Fox is Evil's account if they like but it doesn't really help us get to the bottom of the problem
02-06-2011 2:20 PM
at approx 12:30 I created a redirect (tv51 on the first attachment).
At 2pm (90 minutes later) I checked the status of this redirect (see 2nd & 3rd attachments).
tv51 is the same as tv50 etc and you can delete it / recreate it for a few weeks as it is not in use.
02-06-2011 2:24 PM
I'm happy for you to create/delete redirects or whatever on my account.
A thought - is it anything to do with the number of mailboxes, aliases, redirects on my account? (I know I have rather a lot!)
02-06-2011 3:48 PM
Quote from: Bob
Quote from: digital
It has, but my incoming email is being bounced with '5.1.0 - Unknown address error 550-'#5.1.0 Address rejected'. Is that connected?
02-06-2011 5:48 PM
Later...
I spoke too soon: broken again.
03-06-2011 12:28 AM
03-06-2011 10:21 AM
Quote from: jelv A thought - is it anything to do with the number of mailboxes, aliases, redirects on my account? (I know I have rather a lot!)
Out of ten redirects I've just created on my own account, all but one have failed with similar symptoms so I doubt the amount of mailboxes etc. has much bearing on things.
Quote from: digital Fixed now after a phone call to Support. Many thanks to the amazing Sarah!
Later...
I'm assuming it's not the .plus.com addresses as they seem to be working fine?
03-06-2011 11:25 AM
On a redirect we don't have the option of adding the domain name so are you suggesting that having a domain on the account mucks things up
03-06-2011 11:34 AM
03-06-2011 11:51 AM
"The redirects are showing as active and your mailbox has now been refreshed. Please advise if the issue is still ongoing."
Well, they still don't work so I have reported this back on my ticket.
Still, it only took 17hrs 9 mins for them to respond a mere 429% off target.
03-06-2011 12:45 PM
setup a redirect today, still shows as pending, doesn't get redirected.
still have 3 or 4 redirects showing as pending froma few weeks ago
(all .com btw)
03-06-2011 1:23 PM
Quote from: Bob
Later...
That's right, it's the .net address, except it's working again and the ticket's been updated to say no fault could be found. Weird.
03-06-2011 2:24 PM
Quote from: paulh still not working properly for me either.
I'll report back here with any developments we make towards fixing the problem...
03-06-2011 5:32 PM
