Madasafish Password reset
Steviespitfire
I have a Madasafish mail only account with Plusnet, but I do not have an actual Plusnet account login.
I need to change my password as i suspect its been hacked - but do not have the tab under identities to do it.
Help please?
13 REPLIES 13
Fixes: 1,600
Re: Madasafish Password reset
Hi there
You should be able to reset your password via the Madasafish portal here: https://secure.madasafish.com/forgotpassword/
Anoush
Steviespitfire
Hi Anoush,
I tried that - I never receive the reset email.
Fixes: 1,600
That usually happens if the correspondence email address on the account is the same as your Madasafish address. Are you able to update that via the portal and then try the password reset process again?
Fixes: 1,600
Did you manage to get this sorted?
Steviespitfire
Hi
Not had a chance to try yet.
Steve
Diane90
I am having this problem too.  Where exactly can I update the "correspondence email address"?  Thanks in advance.
Diane90
I have the same problem.  How do I navigate to where I can update my "correspondence email address" ?
Thanks in advance!
Fixes: 1,600
You should be able to do that by logging into your Madasafish Account here: https://secure.madasafish.com/myaccountdx/summary/
Diane90
Thanks Anoush,
I found the password reset there and everything seems to be working fine 🙂
Fixes: 1,600
Awesomeness, happy to hear that. Smiley
IF
I'm also having this problem and when I go to the madasafish password reset page and submit forgot my password I don't get an email back.
spraxyt
Resting Legend
Fixes: 75
Are you entering the email address which Madasafish use to communicate with you?
David
IF
Yes I'm using the one that all my emails come to
