Madasafish Issues?
judeedwards
Madasafish Issues?
I have been getting my emails on my madasafish accounts for the most part with no issues.  I haven't had any for the last day or so.
Does anyone know if the service has finally stopped or if there is a service issue of some kind just now?
4 REPLIES 4
Fixes: 391
Re: Madasafish Issues?
@judeedwards The service is still in operation. How do you access your emails - via webmail or a client?
Fixes: 251
Have you exceeded your storage allowance?  IIRC it is just 250MB on the Brightview (MAAF) services.
judeedwards
I POP (I think) into outlook.  It's just come back online and I've got some emails, just.
I do need to clear it down which is such a bother on the squirrel mail/clunky online thingy.
I am going to have to change to a new email I think but am so attached after all these years 🙈
Fixes: 391
@judeedwards If you are using Outlook (which version?) and only receive mail on a desktop/laptop then somewhere in the settings of that client, there should be an option to not save on the server once you have downloaded your messages. I'm afraid I can't help on that though - not used MS mail applications for about 25 years.
