MIME
rongtw
Fixes: 12
MIME
A quick question , PN web mail is is suposed to support MIME ?
as i get a few Emails in MIME format which do not show correctly
9 REPLIES 9
Acassim
Re: MIME
Morning rongtw,
After checking with a few folks around the office I can confirm that the MIME format should be supported and displaying fine.
Would there be any chance we could get a screenshot if what you're seeing so we can investigate this a little more?
Thanks,
Adam C
kmilburn
Re: MIME
Probably worth checking the message header, as that will contain the primary content type,  and if that's wrong the message won't show as expected.
  i.e. the message should have the header
Content-Type: multipart/mixed; boundary=...
rongtw
Fixes: 12
Re: MIME
all i can grab is this with snipping tool , not full email .
unless i am doing summat wrong  Crazy
spraxyt
Aspiring Legend
Fixes: 75
Re: MIME
The snips show HTML encoded tags, like <head> ..  , which won't be interpreted by webmail as HTML though when displayed they probably look OK as text.
When I view the source of an HTML email I've received (in webmail) it starts off as
------=_Part_1158547_1970601389.1403166161913
Content-Type: text/html; charset="utf-8"
Content-Transfer-Encoding: quoted-printable
<html><head>        <title>... the proper title ...</title>    </head>
with < and > showing correctly rather than as HTML encoded entities. Webmail displays this correctly.
David
Jaggies
Re: MIME
@ rongtw - What browser are you using, and does it do the same if you try a different one?
kmilburn
Re: MIME
That second capture gives away the source of the problem,  DPD don't seem to encode their messages in a friendly format,  as seen before
rongtw
Fixes: 12
Re: MIME
@Jaggies , i use FF30 .
unfortunately i dont use any other
Jaggies
Re: MIME
@ rongtw - As per the post from kmilburn, the source of the problem is the sender's software (or is it their ISP?)
Nothing to do with your browser choice, but I asked the question to rule it out.
rongtw
Fixes: 12
Re: MIME
Ahhh i see  , at least i know its not PN email now  Cool
Thanks Jaggies
