Login rejected
- Re: Login rejected
Login rejected
22-06-2014 7:07 PM
Presumably some sort of server problem, it's a pity that the response always seems to suggest that the password is wrong.
Edit: Sorry, I did not originally clarify this is not a problem with the Plusnet email server - it's an account with another provider. I was just having a bit of a moan because I know the message frightens a lot of people into entering their password into the pop-up windows and then trying 'alternatives' when the first attempt fails to work. There has got to be a better system.
Quote Receiving' reported error (0x800CCC92) : 'Your e-mail server rejected your login. Verify your user name and password in your account properties. Under Tools, click E-mail accounts. The server responded: -ERR Authentication failed.'
Message 1 of 2
(790 Views)
1 REPLY 1
Re: Login rejected
23-06-2014 9:07 PM
My main grip about PlusNet webmail logging in is that it doesn't tell you that you have Caps Lock on (when you have) unlike other more helpful sites...
Message 2 of 2
(426 Views)
