Location of incoming webmail
FIXED- Subscribe to RSS Feed
- Location of incoming webmail
Re: Location of incoming webmail
03-06-2017 6:57 PM
Hello again. I use Outlook for email and it is set up as POP3 not IMAP. Incoming mailserver mail.freenetname.co.uk and outgoing mailserver SMTPmail.freenetname.co.uk
Expanding the problem a little, I send all emails out no problem from Outlook.
The only one that will come back to Outlook inbox is if I address one to myself.
ALL other incoming email does not appear ANYWHERE in Outlook and ONLY appears in PlusNet WEBMAIL junk folder. Moving it manually from Junk folder to inbox on WEBmail instantly sends it also to OUTLOOK inbox.
Hope this helps. Thankyou again.
03-06-2017 7:59 PM
Thanks, that's useful background. It looks like the mapping from Freenetname to Plusnet mail storage might not be correct. Hopefully a mail support team member will pick this up on Monday and resolve the problem.
05-06-2017 9:49 AM
12-06-2017 3:34 PM
Hi Guys, Any progress? It's been a week now. I am still only receiving emails into my WEBMAIL JUNK folder, and having to re-distribute them from there. ( They are NOT marked as spam ).
This is a complete pain now !!!
12-06-2017 4:56 PM
14-06-2017 3:56 PM
Details submitted in a PM to you as per your request.
14-06-2017 4:34 PM
15-06-2017 5:31 PM
Looks like this is fixed now.
I'm wondering whether or not the legacy 'safe mail' feature or some other filtering was enabled on the old Madasafish Webmail platform before your account was migrated across to the Plusnet Webmail system. That would certainly explain why all messages might have ended up in the Junk folder.
Anyway, shout up should the problem continue.
16-06-2017 4:36 PM
Emails now going happily to my Outlook and Gmail inboxes. The only place they DON'T go strangely, is my PlusNet Email inbox, but I guess I can live with that if you can't fix that also. Thank you for your efforts for me.
16-06-2017 5:00 PM - edited 16-06-2017 5:01 PM
You mentioned in an earlier post that you used POP3 with Outlook to collect mail. The default setting is usually to delete messages from the server after collection. Unless you've changed this collected messages will no longer show in webmail.
17-06-2017 12:09 AM
Hi David, Thanks for the message, but you missed the point.
I collect emails ( Outlook POP 3 ) no problem. Happy with that.
The messages DO stay on PlusNet WEBmail. No problem, happy with that.
The messages do NOT go to my PlusNet EMAIL inbox ( as opposed to WEBmail inbox ).
However, as I said, I can live with that if you can't fix it.
Would be nice to get a response to this.
Evelia
17-06-2017 4:58 PM
For most people reading this they are both the same thing. Maybe a bit more explaining is required.
17-06-2017 7:46 PM
I think this is a matter of terminology. The OP mentioned in Reply #16 having a freenetname email address and I assume it is that inbox which is being accessed using Plusnet Webmail (https://webmail.plus.net) and referred to as the "Webmail inbox".
However it looks like the OP also has a Plusnet account with accountname.plus.com email address and it is the inbox for that account which is being referred to as the "Plusnet Email inbox".
The Plusnet and freenetname mail stores will be physically separate so I would expect freenetname emails not to appear in the Plusnet account inbox (or vice-versa). However that needs to be confirmed by a staff member.
17-06-2017 10:46 PM
@spraxyt, your assumption is correct. The Plusnet email address and the Freenetname address are entirely separate. They can both be accessed via the Plusnet Email interface (and a separate mail client like Outlook), but the login and server credentials for each address are different).
17-06-2017 11:53 PM
Thanks David, all you say is correct. The only thing that my ( logical ) mind was having difficulty in accepting was the fact that now the fix is in place, and working, the webmails are now automatically not only going to my Outlook inbox but also to my Gmail inbox ( which I see as a totally separate entity ), but NOT to the username.plus.com location. However, I am happy to accept the end result, and thankyou very much. I will try to learn more about this. I appreciate your efforts made on my behalf.
