Linking Mailboxes to Domains
- Linking Mailboxes to Domains
25-04-2010 9:45 PM
Not sure whether this should be here or in the Domains & Hosting forum but I need to find a way of ensuring I have separate mailboxes for each of the 3 domains that I have hosted.
Seems simple but for the last few years all the e-mail to the domains has been going to my default mailbox and then filtered once downloaded. However I can't find any way of simply setting up a mailbox and linking it to a specific domain. If I try to go the member section for configuring domains I just get an error page telling me there might be a temporary fault and to try again later. I am now still trying 2 weeks later!
All I want is for:
anything@domain1.co.uk to go to mailbox 1
anything@domain2.co.uk to go to mailbox 2
anything@domain3.co.uk to go to mailbox 3
Any advice would be gratefully received!
Andrew
All I want is for:
Andrew
Message 1 of 7
(3,231 Views)
6 REPLIES 6
Re: Linking Mailboxes to Domains
25-04-2010 9:55 PM
AFAIK it isn't possible - I asked for this sometime ago and it never happened as it was in the too difficult category
Example I wanted me@username.plus.com to go to a separate mailbox from me@username.co.uk
The problem is that email coming into all the domains goes into a single pot and is then sorted by mailbox name with the domain name ignored
Message 2 of 7
(1,797 Views)
25-04-2010 10:04 PM
Oh well, it seemed to me as if it should be easy to do!
Is it worth asking again do you think? How long ago did you raise the question?
Thanks anyway
Andrew
Thanks anyway
Andrew
Message 3 of 7
(1,797 Views)
25-04-2010 10:14 PM
Message 4 of 7
(1,797 Views)
25-04-2010 11:19 PM
...and at the Usergroup... here
Message 5 of 7
(1,797 Views)
01-05-2010 7:42 AM
I raised a ticket anyway and the answer is still "no". There is also no way of setting up any delivery rules on the Plusnet side either so it looks like everything still has to be sorted out on the client side.
Message 6 of 7
(1,797 Views)
01-05-2010 10:55 AM
Where have you got you domains registered. If you use the likes of Fasthosts would their email forwarding do want you want? http://www.fasthosts.co.uk/domains/features-pricing/email-forwarding/
Message 7 of 7
(1,797 Views)
