Is there a problem?
- Is there a problem?
Is there a problem?
06-07-2010 8:23 AM
Have tried to access my email this morning via Thunderbird at 0815 (three times) and keep getting this message
e
Webmail is working OK.....
e
The connection was reset
The document contains no data.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Thunderbird is permitted to access the Web.
Message 1 of 2
(750 Views)
1 REPLY 1
Re: Is there a problem?
06-07-2010 8:26 AM
Nope ! ! it seems there isn`t a problem.!
just tried again..... and it worked ok...
Great service PlusNet ! ! !
Message 2 of 2
(164 Views)
