Is there a problem with MAAF email?
Mayfly
All Star
Have tried 6 times this morning to forward an email to my PC from MAAF via PN.
It's a bit of a complicated route but has worked for the last 6-7 years. Yet this morning all indications are it's working fine but the email is getting lost in cyberspace somewhere.
I can send one to myself both from Outlook on my PC and from MAAF webmail but I can't get this particular one to forward.
1 REPLY 1
bobpullen
Fixes: 315
Re: Is there a problem with MAAF email?
No problems I'm aware of.
Quote from: Mayfly
You'll probably need to elaborate on this.
What email client are you using to forward the message? e.g. Webmail? Outlook?
What address are you sending from?
What address are you sending to?
If using a standalone client like Outlook then what outbound/SMTP server are you using?
You're probably best to obscure parts of your email addresses if you post them here.
