Interface Skins - Roundcube Webmail
- Re: Interface Skins - Roundcube Webmail
16-05-2012 1:19 PM
this is not really a big issue but just wanted to see what other people have found. If i use webmail and try to change my personal settings so the user interface to webmail uses a different skin, i change it then click apply e.g from roundcubeskinplusnet to say Roundcube or one of the others, Click save and it says ok saved succesfully i then try to logout of webmail and then log back in but no changes have taken affect and when i check the settings its changed it back to the defailt skin.
Anyone else tried or had this.
Message 1 of 5
(2,452 Views)
4 REPLIES 4
17-05-2012 11:42 AM
It hasn't saved even before you log out - it looks like they have hard linked the skin to which vISP you log in to. If you look at the skins listed there are skins for each of their brands.
Message 2 of 5
(948 Views)
17-05-2012 12:09 PM
It doesn't want to play at all. Also if you select the plain "PlusnetSkin" further down the list it comes up with SERVICE CURRENTLY NOT AVAILABLE! Error No. [501] .
Message 3 of 5
(948 Views)
18-05-2012 9:20 AM
Message 4 of 5
(948 Views)
18-05-2012 11:18 AM
Poor Bob
Message 5 of 5
(948 Views)
