Incredimail
- Incredimail
Incredimail
23-06-2010 7:29 PM
I am new to Plusnet and would like to use Incredimail to receive my emails could you let me know if this is possible and if so how I do it. Thanks in advance for any help received,.
Re: Incredimail
23-06-2010 8:10 PM
With regards to Incredimail the settings are exactly the same as for Outlook Express/Windows Mail and can be found
HERE.
Is there any reason why you want to install Incredimail? It is very intrusive, sometimes a bit awkward to remove and many people don't care for it, particularly when they receive emails full of links.
Hope you don't mind this suggestion but have you tried Windows Live Mail?
It has a lovely clean interface and is quite easy to use once you have got used to it.
Instructions are on the aforementioned web page.
Re: Incredimail
23-06-2010 8:49 PM
Re: Incredimail
23-06-2010 9:22 PM
Re: Incredimail
23-06-2010 9:43 PM
I would suggest the OP try other software, Outlook, Windows Mail or Thunderbird.
Re: Incredimail
23-06-2010 10:07 PM
Re: Incredimail
24-06-2010 8:35 AM
Thank you all for your input re incredimail, I have never had a problem but will certainly take on board what you say. I do have a Live email account so will try using that.
All went very smooth with change over I was very impressed, hope to have as long association with Plusnet as I have had with Virgin.
Re: Incredimail
24-06-2010 8:42 AM
Re: Incredimail
24-06-2010 9:13 AM
Nowadays my emailing is much more basic.
Anyway, if you like it then that's fine and as has been said, just set it up with OE settings on the link provided.
