Incoming emails stopped
- Re: Incoming emails stopped
Re: Incoming emails stopped. Again.
06-12-2018 2:08 PM - edited 06-12-2018 2:09 PM
My message posted twice, edit deletes second identical reply.
08-12-2018 1:38 PM
08-12-2018 1:45 PM
Ah, it looks like these old e-mails are showing up in my inbox as 'new' (ie: date now) . I've just downloaded 27 'current' e-mails but only 15 are actually new. The rest are 2017 duplicates but that's not how they are displaying on WebMail.
08-12-2018 5:47 PM
@Riverside Webmail sometimes mixes up message arrival and sent dates due to incomplete list option selections.
If you click on the List Options icon to the left of the subject heading do the settings tie up with those I use shown in the following image?
10-12-2018 8:45 PM
Almost - the entry in the 'Sorting Column' was set to None so i've switched it to 'Sent Date'.
Tonight I took a screen shot of my WebMail inbox. I had 27 to download, all from Saturday to date.
Well, I received 27 ok. 16 are new but 11 were from 2017, and all of those 2017 mails do match any of the subject headers visible in the screen shot.
So WebMail is showing one thing, but I am receiving something else?
11-12-2018 10:33 AM
Hi @Riverside,
Checking your mailbox displays no emails therefore, these appear to have been downloaded.
It could potentially be due to settings on Thunderbird, such as separating new / unread emails and emails in the inbox. Please click this icon in the header of the column while in your inbox to see if the missing emails reappear. If not, below I have added an image of a filter that may be applied, please deselect this option if it is enabled.
Let us know how you get on.
Thank you.
11-12-2018 7:00 PM
Thanks - Work in progress: tonight 10 in, 10 out, no old duplicates.
11-12-2018 11:32 PM
@Riverside Since you download messages to Thunderbird using POP3 I assume having an empty Inbox online would be acceptable. perhaps desirable as a new base point.
I suggest you login to Webmail. display the Inbox then click the Cog icon bottom left. This should give you an option list with Compact at the top. click this and allow Webmail to work through the operation, it might take a few seconds but could be much longer if lots of wasted space needs to be recovered.
You might notice that another of the Cog options is Empty but this will be greyed out on the Inbox since clicking it would have undesirable side effects - all messages instantly disappear and can't be recovered.
Assuming you are happy to empty the Inbox, return to the message list and click the small square block icon on the strip below the list. This should cause all messages to be selected, including any that are beyond the range of messages on the current page. Now click the Delete menu option - the red circle with diagonal line. Allow time for this to complete.
Compact Inbox again and I anticipate it will transiently respond No messages.
Finally select Deleted Items or Trash (which is shown depends on settings). Click the Cog again and this time Empty should be an option - in which case choose it.
Hopefully working through these steps will have removed any old 2017 messages from the server so they can't download again.
16-12-2018 9:32 PM
i Have been experiencing the same problem with my totalise email account. Out of the blue, it has resolved itself but now my wife has the same problem with her totalise email account. She can send emails but not receive any. I have tried web mail for her but cannot get past sign in as her user name and/or password are regarded as incorrect. We are both using iPads on IOS 12
we have had these email accounts many years. Totalise was taken over by Madasafish and then Plusnet and we have stayed with them all the way.
any suggestions please?
17-12-2018 11:50 AM
Hi @Zaq1,
I'm sorry that your wife is unable to receive emails to her account at the moment and for any inconvenience that this is causing. I've refreshed the mail component on the account to try and resolve this and this should take effect within the next 24 hours. Please let us know if the issue persists after this.
18-12-2018 9:11 AM
No, still no emails received since last Thursday - five days now.
18-12-2018 11:08 AM
19-12-2018 4:34 PM
EIt gets even stranger.
We cannot now log in to her webmail using the password we used to set up her totalise email account on her iPad and laptop. Just get a ‘log in failed ‘ message
I have set up her email account on my iPad to check the correctness of the password and it sets up and functions ok but only on sending, not on receiving
Still able to send but not receive from totalise email address on her iPad either.
19-12-2018 4:40 PM
19-12-2018 4:45 PM
How do I PM you?
