Importing address book
- Importing address book
30-04-2012 5:19 PM
Re: Importing address book
30-04-2012 5:20 PM
30-04-2012 7:03 PM
30-04-2012 7:05 PM
30-04-2012 7:52 PM
OK this may work
http://www.freeemailtutorials.com/windowsLiveMail/addressBooksAndContacts/exportContacts.htm
Export as .vcf
Open Webmail then select Address Book and Import Contacts - I think it is the 4th icon from the left
30-04-2012 9:08 PM
Edit: clarification.
30-04-2012 9:16 PM
30-04-2012 10:15 PM
Depending on the size of the address book, it's going to be a bit tedious exporting one by one so he may go searching for means to do it in one go. As such he should be aware of that thread, as both spraxyt and myself have still yet to find a guaranteed secure method to extract the whole address book in one go into one file, rather than one by one.
30-04-2012 10:18 PM
Quote from: spraxyt Do you mean you have lots of individual .vcf files which you want to merge into a single file?
That's easy to do on a PC in a command prompt window.
cd to appropriate folder and do
copy *.vcf all.vcf
30-04-2012 10:24 PM
30-04-2012 10:45 PM
And spraxyt's trick that you've quoted nicely deals with the multiple file scenario.
I'm still looking for a way of doing it from OE, I'll go back to the other thread for that issue.
01-05-2012 2:29 PM
Anyway guys thanks very much for your help - it seemed to spark some discussion.
