Imap client sees folders inside inbox
- Imap client sees folders inside inbox
15-10-2013 10:02 PM
I've just set up a Plusnet mailbox account to be accessed from Mac OSX Microsoft Outlook via IMAP and all of the "system" folders (sent,deleted,drafts,etc) are shown as sub-folders of the INBOX. They don't display this way on PlusNet's webmail (roundcube) and neither do other (non-plusnet) IMAP accounts (e.g. iCloud) when used on the same Outlook client.
Ideally, things like sent, deleted and drafts would exist at the same level as inbox so that the client renders them correctly.
Any ideas why I'm getting this is and can I change it ?
Thanks in advance.
Thanks in advance.
Message 1 of 5
(1,648 Views)
4 REPLIES 4
Re: Imap client sees folders inside inbox
15-10-2013 11:22 PM
That layout is fairly typical of IMAP servers.
With outlook, there is a possibility of changing its behaviour going by this http://www.msoutlook.info/question/619
Message 2 of 5
(690 Views)
16-10-2013 12:30 AM
It's the way Thunderbird displays them and so does the old basic webmail (Squirrelmail).
Message 3 of 5
(690 Views)
16-10-2013 2:27 PM
Quote from: kmilburn That layout is fairly typical of IMAP servers.
I think this looks like the answer but it didn't work when I tried it.
I tried "INBOX" and "Inbox" but neither made any difference. Any ideas?
Message 4 of 5
(690 Views)
18-10-2013 11:17 AM
You're seeing this due to the way the namespace is configured for our mail server (Courier). Using Outlook 2007 I was able to flatten the folder hierarchy using 'INBOX' (minus quotes).
. list """*"
* LIST (\HasNoChildren) "." "INBOX.Test"
* LIST (\HasNoChildren) "." "INBOX.Drafts"
* LIST (\HasNoChildren) "." "INBOX.Trash"
* LIST (\HasNoChildren) "." "INBOX.Sent"
* LIST (\HasNoChildren) "." "INBOX.Spam"
* LIST (\Unmarked \HasChildren) "." "INBOX"
. OK LIST completed
Message 5 of 5
(690 Views)
