IMAP sending
- Re: IMAP sending
IMAP sending
01-09-2010 8:03 PM
Hi
I've set Thunderbird up with an IMAP account (as per a previous thread), but if I try to reply via that account, I get asked for a password. When I enter my FOL password, it comes up with a failed to send message and asks if I want to retry, then it asks for a password ...
What am I doing wrong?
Message 1 of 7
(1,216 Views)
6 REPLIES 6
Re: IMAP sending
01-09-2010 8:10 PM
the outgoing is as below
Message 2 of 7
(524 Views)
Re: IMAP sending
01-09-2010 8:12 PM
Blimey - that was quick - Thanks
EDIT - Whoops - spoke too soon. I found that screen and that's what it says (except it's only got my short user name. Do I need to put username@free-online.net or something?
J
J
Message 3 of 7
(524 Views)
Re: IMAP sending
01-09-2010 8:26 PM
fred@username.free-online.net
or looking at my sudo name
fred@username.free-online.co.uk
have you ever tried fred@username.idps.co.uk (I dont pay subscription), it saves a lot of typing and it works
Message 4 of 7
(524 Views)
Re: IMAP sending
01-09-2010 8:27 PM
Got it! It was picking up a different SMTP setting, using "john" as my user name and not my proper one - thanks for the help.
Message 5 of 7
(524 Views)
Re: IMAP sending
01-09-2010 8:31 PM
just done and edit above try that
Message 6 of 7
(524 Views)
Re: IMAP sending
01-09-2010 8:34 PM
Hi
Yes I usually use the idps address. You're right it saves on finger-strain
All working now. It only needed the proper user name (not the rest of the address)
Message 7 of 7
(524 Views)
