IMAP rules
- Re: IMAP rules
IMAP rules
01-03-2011 9:09 PM
I've looked in the webmail settings and the e-mail settings on my account, but I can't see anything.
If it's not possible at the moment, is it something that's likely to be implemented in the future?
Re: IMAP rules
01-03-2011 9:19 PM
https://portal.plus.net/my.html?3A9gtk3TO7Vnm5tygj41WxGvNgoXUgKqC3f0fFmIgOsmrrsujjYNOoAbUr2%2FgAxC&r...
Re: IMAP rules
01-03-2011 9:24 PM
Re: IMAP rules
01-03-2011 9:41 PM
"Unfortunately, this feature is not available with your current account. To raise any queries and to upgrade your account, please use the Contact Us tool here at the Portal"
The kind of rules I'm talking about are message rules that would automatically move certain e-mails into certain folders. The kind of thing that's easy to set up in e-mail clients, but I think that it's possible for it to be done on the server automatically.
Edit:
This kind of thing:
http://community.plus.net/forum/index.php/topic,16041
Re: IMAP rules
01-03-2011 9:50 PM
Re: IMAP rules
01-03-2011 10:15 PM
Quote If you are an existing customer
If you have recently joined PlusNet
It may take up to 30 minutes until you can access this feature of your account. Please try again later. Go back
Re: IMAP rules
01-03-2011 10:29 PM
But I don't think that does what you want
Re: IMAP rules
01-03-2011 10:44 PM
Annoys the hell out of me, I see that stupid page several times a day, and I wish I didn't.
Re: IMAP rules
01-03-2011 10:50 PM
Re: IMAP rules
01-03-2011 11:10 PM
@pierre_pierre:
I just can't see how one can set those message rules up. I looked through all the Manage My Mail settings before posting on the forum, and have just looked through them again.
The screen that I see looks the same as the screenshot that you kindly uploaded. Which tab did you click on to create the rules?
Re: IMAP rules
01-03-2011 11:28 PM
The best you can do is to set up rules in client software to move emails as you need - then however you subsequently view the mailbox you will see the emails where you want (including in webmail). Unfortunately that isn't going to help you if you normally go in via webmail so your client doesn't get to do it's stuff first.
Re: IMAP rules
02-03-2011 7:49 AM
When I use Outlook express you can do more sub folder local
Re: IMAP rules
02-03-2011 9:44 AM
If you think it can be done please give be step by step instructions on how to set the following up on the Plusnet servers so that without me running any client (e.g. Thunderbird or Outlook etc) so that when I log in to webmail emails received are already in the correct folder:
I have a mailbox called John, most of my emails coming in are sent to john@mydomain.me.uk or john@username.plus.com. Using IMAP I have created a number of folders underneath it. According to the following rules I want emails moved:
If the sender is mybrother@hisdomain.co.uk or mysister@herdomain.com I want the emails moved to a sub-folder called of the inbox called Family
If the subject of an email begins [RecycleGiftingMidSussex (Freegle)] or either of the other Freegle groups I belong to I want the email moved to a sub-folder of the inbox (still within the mailbox John) called Freegle.
Re: IMAP rules
02-03-2011 10:33 AM
do it like I did with the Odds. make a mail box called family then set up alias rules to send mum@, sister@,brother@ to family then on web mail they will be in jelv+family
Re: IMAP rules
02-03-2011 10:39 AM
The emails are all sent to john@mydomain.me.uk or john@username.plus.com - they will all end up in the mailbox John.
It is the senders address that has to be checked to move to the appropriate folder within that mailbox.
