How long to restore archived emails?
HarryB
Fixes: 256
Re: How long to restore archived emails?
Further to our previous response, it looks like your emails have now been unarchived @LisaA
Given the amount of mail in there, it may take a while to load in webmail, however I'd politely request that you reduce the mailbox size by deleting/making a local backup of any important emails and removing them from the server to bring the total amount back below the 1GB limit in our acceptable use policy.
If you're still having any problems with this, please do let us know.
Thanks.
 Harry Beesley
LisaA
EmilyD thank you so much for pushing this through finally! As soon as I saw your message, the emails started filtering through. I've now had everything returned & managed to clean my webmail inbox to the required minimum 1 gb.
LisaA
Thanks HarryB, all fixed now.
And apologies to NigelK for hijacking his thread to solve my problem. Does this count as a double fix for all of you who jumped into help?!.
I've also cleared out my inbox down to the allowance of 1 gb & backed up all the essentials.
LaurenB
Fixes: 131
Glad to hear this is sorted @LisaA Smiley
Please get back to us if you have any further issues.
 Lauren Barry
Fixes: 160
Just in case ... also remember to delete the contents of the Trash / Deleted Items folder.
lauramc
i have been waiting 2 weeks for my archived emails to be returned. still waiting
MatthewWheeler
Fixes: 479
@lauramc I'm really sorry to hear that your e-mails haven't been unarchived.
I've requested this for you now and the e-mails should be restored in the next hour or so,
Again apologies for any inconvenience caused
 Matthew Wheeler
lauramc
i havent had them all restored but i have deleted lots and still getting messages to tell me to lower my mailbox?
spraxyt
Resting Legend
Fixes: 75
1) After you deleted messages did you empty the Deleted/Trash folder and also compact the Inbox and any other folders where messages have been deleted? Until these actions have been carried out even though flagged as deleted the messages will still take up storage space.
2) Have you checked the contents of all your mailboxes (if you have more than just the default one)?
David
lauramc
i dont know how to compact them.. i did see them all arriving but then they disappeared again?Huh
spraxyt
Resting Legend
Fixes: 75
Folders can be compacted using webmail. Login and select the folder you want to compact. Then click the cog icon bottom left which should open a small options pop-up showing
Click Compact on that to do the necessary.
The Empty option is greyed out there but for Deleted Items this could be used to empty that folder.
David
lauramc
thankyou!
lauramc
they told me they had restored mine but they havent appeared in my inbox yet either
deank
Fixes: 14
Hi @lauramc
Did any of your emails re-appear at all? If not, I'll get this escalated back to find out why this is the case.
lauramc
i am at my wits end! have had another email saying to reduce my mailbox but when i go into it i only have 300 emails? the ones that were archived i still cant see although i was told they would be returned to my mailbox?. my son had an email address through this account but he deleted his last week as he doesnt use it? any simple way to help. is there a tutorial?
